1994 C 220 Trans problem - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-04-2007, 07:14 AM Thread Starter
Date registered: Mar 2007
Hello,
I have a problem with my tranny.Its kicking sometimes.Shifts fine thru all gears but harder sometimes no matter if cold or hot..I took it to my local dealer and they said,that Kickdown element needs to be replaced-$750.I went to the trans.shop and they said there is no problem with tranny at all,but the front differential bearing needs to be changed-$400.I don't know what to do now.Any help?
kingule is offline
post #2 of 4 (permalink) Old 03-04-2007, 06:45 PM
Date registered: Apr 2004
Vehicle: 02 C3AMG /87 560SEC/ 87 300TD/ 85 928 EURO
How hard your transmission (722.4) shifts is regulated by engine vacuum. You could have a vacuum leak to the modulator, or a defective modulator. Check all the vacuum hoses on the engine for cracks.
Your car may have an up shift delay actuator, which can also have a leak. The best method to check for a leak is with a smoke machine; find a shop that knows works on MB.
www.MasterTechtrans.com
Steve Cattaneo
02 C32 AMG
87 560 SEC
87 300D
85 928 S2 euro
83 928 S
85 325 IS BMW
C32AMG/02 is offline
post #3 of 4 (permalink) Old 03-05-2007, 06:26 AM Thread Starter
Thumbs up
Thank you,I am going back to the dealer and will ask them about it.Let you know)
kingule is offline
post #4 of 4 (permalink) Old 03-12-2007, 06:49 PM Thread Starter
Unhappy
Tranny fluid changed ,much better now
kingule is offline
    W 202, C 220 DIESEL EDC PROBLEM AIOVAS W202 C-Class 9 04-27-2011 04:43 AM
    c 220 diesel combi instrument problem gudikcik W202 C-Class 0 03-30-2006 04:36 PM
    Possible Trans Problem? HELP! aerosnout W124 E,CE,D,TD Class 6 05-09-2005 08:40 AM
    1994 S600 coupe "Vacuum assist pump problem and now a starting problem Bigpauly52 W140 S-Class 18 09-26-2004 12:36 AM
    E 220 problem,please help traxdata W124 E,CE,D,TD Class 6 07-08-2004 05:59 AM
