Instrument cluster lamp replacement doesn't work - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-27-2007, 03:59 PM Thread Starter
Date registered: Feb 2007
Unhappy Instrument cluster lamp replacement doesn't work
Please help!
I've a 1997 E320, and I need to replace 2 lamps in the instrument panel. After repelling offers from the dealer to do it for me, they finally succumbed to selling me the bulbs so I could do it myself.
I got the cluster out without difficulty, and easily located the bulbs. I replaced one, switched on the lights, and it worked great. But the second one, an identical bulb in another spot on the cluster, simply won't work. I did all the obvious - made sure the replacement bulb was actually working OK, and still nothing.
Please help - what could be wrong do you think?
scloughley is offline
post #2 of 3 (permalink) Old 02-27-2007, 06:57 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hi, SC, and welcome to the forum.
There's really only three possibilities, either the socket is bad (if this is one of the insert-and-twist-in-type it's an easy and cheap fix), the contact surfaces for the socket on the cluster are corroded (perhaps easy and cheap, depending...), or there's a break in the circuit board that feeds the contact surfaces (neither easy nor cheap). I'd probably start by checking for current flow at the contact surfaces, if you find it you're 90% there.
(and kudos to you for successfully repelling the monster.)
Good luck and enjoy the ride,
Greg
Check Codes is offline
post #3 of 3 (permalink) Old 02-27-2007, 08:32 PM
Canadian_Yeti's Avatar
Date registered: Oct 2006
Vehicle: 2003 C230K Evo
It is advisable to replace all the bulbs while you have it apart. It'll save you alot of frustration if a couple more decide to go in a week or two!
Canadian_Yeti is offline
    Instrument cluster replacement chuckmcdonald W210 E-Class 32 02-21-2012 04:29 PM
    Instrument cluster replacement Taters W202 C-Class 8 07-14-2010 08:25 PM
    Instrument Panel Lamp Replacement Brody C208/A208 CLK-Class 9 07-23-2009 01:26 AM
    NEED REPLACEMENT INSTRUMENT CLUSTER HMCGARY W140 S-Class 0 12-04-2004 11:23 AM
    anyone upgraded the 96-99 cluster to the 00-03 instrument cluster? will it work?? spine911 W210 E-Class 8 11-12-2004 04:24 PM
