To Buy or Not: 95 C220, 14,000 Miles - Page 2 - Mercedes-Benz Forum
post #11 of 14 (permalink) Old 03-01-2007, 04:24 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Originally Posted by elvisvf51
Question: Would you go? Should the '95 C220 be feared?
If you don't fear the F-14, the C220 shouldn't be a problem.
flyboyike is offline
post #12 of 14 (permalink) Old 03-01-2007, 08:03 PM Thread Starter
elvisvf51's Avatar
Date registered: May 2005
Vehicle: '95 E300D 85k, '88 190E 2.3 140k
Cascade: Thanks for the referral, I'll check them out.
Musikmann: Verry Interrreszztingk...
Flyboyike: I fear the fact that I did not fear the F-14 when I was flying it. Also, fuel and maintenance was free!
elvisvf51 is offline
post #13 of 14 (permalink) Old 03-01-2007, 10:47 PM
Kajtek1's Avatar
Quoted: 1226 Post(s)
Originally Posted by Musikmann
I'd keep the 190E, and buy the C220.
EXACTLY.
If you pass the deal, let me know immediately. I am 30 minutes from Pleasanton.
For 500 miles drive to La Jolla you'll very likely need new tires, or trailer.
Kajtek1 is online now
post #14 of 14 (permalink) Old 03-23-2007, 07:20 PM Thread Starter
elvisvf51's Avatar
OK. Here's the pre-buy inspection summary.
On a scale of 1-10, the mechanic says it's a 9.5; 13,881 miles.
Compression 124/60, breaks good, no leaks
Here's the list of things that need to be fixed:
Fuel Level (Tank) Sensor: Replace
Left & Right side front turn signal housings w/right side lower headlamp trim: fix
A/C: recharge
Flex disc: replace
Oil fill cap: replace
Camshaft sensor: replace
Spark Plugs : replace
Transmission : service
Brake fluid : Flush
Tires : replace
Wheels : align
Battery : Replace
I figure about $2500 all in w/labor. I'll think about an offer. Any thougts?
    Need Advice on a 1990 300Diesel 89,000 miles, I might buy it... SpiderBC1 W124 E,CE,D,TD Class 5 12-01-2007 06:16 PM
    1997 E420 170,000 Miles, Crazy to buy? camillo4u W210 E-Class 10 11-25-2006 12:12 PM
    42,000 miles - what oil do i buy? krk230 R170 SLK-Class 4 01-02-2006 06:28 PM
    G500 factory Buy Back after 40,000+ miles smalk G-Class 5 10-10-2005 10:16 PM
    Should I buy a 2000 E320 4matic with 135,000 miles? johnciowa W210 E-Class 3 02-18-2004 01:42 PM
