1992 300TE 4Matic Vs. 2000 E320 4Matic - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 02-26-2007, 10:03 AM Thread Starter
Date registered: Feb 2007
Vehicle: 2000 E320 4Matic Wagon
Question 1992 300TE 4Matic Vs. 2000 E320 4Matic
We're in the middle of trying to decide what wagon to replace our Volvo with and are looking at a 1992 300TE 4Matic and a 2000 E320 4Matic for Mercedes. Certainly the cost is different, but I'm more interested in reliability. A few years ago I had a 1990 300TE 4M and it was always in the shop. Any thoughts on the relative quality of these two models? The mileage is about the same (150K) but the 2000 seems to have been very well taken care of even with the high miles. Another option is a 1998 wagon, but it seems like these are considered fairly low in reliability.
thanks for any insigts
dogwagon is offline
post #2 of 6 (permalink) Old 02-26-2007, 10:08 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
W124 4matics are a disaster.
W210 versions are fine.
Kent Christensen
'07 GL320CDI
lkchris is offline
post #3 of 6 (permalink) Old 02-26-2007, 11:59 AM
Musikmann's Avatar
Quoted: 5 Post(s)
Without hesitation I would recommend the 2000 E320 4matic. As Kent wrote, the earlier ones were pretty bad - At some point, Mercedes completely re-designed their AWD vehicles, so the "newer" ones are fine.
However, the RWD W124s have proven to be very reliable.
Musikmann is offline
post #4 of 6 (permalink) Old 02-26-2007, 01:20 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
Yup, go with the w210.
GeeS is offline
post #5 of 6 (permalink) Old 02-26-2007, 02:37 PM
Kajtek1's Avatar
Quoted: 1064 Post(s)
Welll... if the price is not object, definitely go with 210.
4-Matic in 124 was limited time only -engaged at low speeds and certain situations. Constant switching on/off under the load doesn't last in any machine, so 210 is having 4-Matic all the time.
Bottom line -when the transfer case in 124 blows up -you continue the driving on 2 WD mode and my believe is that how most of those 4-Matic drive as of today.
When it brakes on 210 -you are stranded. I had front CV joint going bad on my 210 wagon and that turn to be very costly repair due to the fact that the smallest part MB sells is whole axle.
Kajtek1 is online now
post #6 of 6 (permalink) Old 02-27-2007, 09:31 PM Thread Starter
We went with the 2000, thanks for all of the input
dogwagon is offline
    300TE 4Matic to non-4matic conversion hellspcangel911 W124 E,CE,D,TD Class 15 09-17-2012 12:17 AM
    2001 E430 4matic or 2002 E320 4matic alexnatt W210 E-Class 16 08-02-2010 10:54 PM
    1992 300TE 4Matic - need valve block stummala W124 E,CE,D,TD Class 2 12-08-2006 05:13 PM
    Considering Buying a 1992 300TE 4Matic graddini W124 E,CE,D,TD Class 2 06-30-2006 08:09 AM
    MY 2000 - E320 4matic wagon Sanjay W210 E-Class 1 05-06-2005 04:32 PM
