best economical repair of vinyl - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 02-23-2007, 02:24 PM Thread Starter
Date registered: Feb 2007
am wishing to repair a dime sized hole which came with my 79 300d. hole is to the passenger door vinyl and is not a tear with a flap so there is no" flap to glue down." i guess, therefore, i will need to plug the hole with goop and heat across it in order for it to adhere to the vinyl. are any of the repair kits offered on the market better than others ? any advice for mixing the colors in those kits to match palomino? thank you in advance for your advice. abbyelk.
abbyelk is offline
    What engine is more economical:E200 or E220 (93-94)? Guest (MBNZ) W124 E,CE,D,TD Class 7 11-09-2012 05:13 AM
    Need name of vinyl burqueDOKA G-Class 0 08-03-2006 03:31 PM
    in which year was the most refined, economical w126 built? eso7 W126 S,SE,SEC,SEL,SD,SDL Class 3 10-16-2004 06:36 PM
    What is the best and most economical way to install dvd,nav in the Ml98?? biffy W163 M-Class 3 04-12-2004 04:22 PM
    Will alcohol based vinyl cleaners/preservers cause vinyl to dry out and crack? Chris(LE) R170 SLK-Class 5 08-27-2001 03:54 PM
