False "Fault" Alerts??? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-21-2007, 07:08 AM Thread Starter
Date registered: Feb 2007
Vehicle: 2002 C230 Sport
I currently am getting the following faults on my 2002 C230 Sport:
"Reverse Light, L
Check Lamp!"
"Turn Signal, L
Check Lamp!"
"Tail Light, R
Substitue Lamp On!"
"3rd Stop Lamp
Check Lamp!"
When I inspect the lights- they all work. On occasion, I will have up to three additional faults referring to various other lamps. Is there something I can check within the electrical system that may be causing these faults?
Virgos13 is offline
post #2 of 4 (permalink) Old 02-21-2007, 10:18 AM
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
Quoted: 2 Post(s)
It could be a fault in the electrical system, but I would take it to my dealer to diagnose that. It is also common for the metal light bulb fixtures on our cars to corrode and cause faults. Just because all lights appear to be working doesn't mean they are. As I understand it, they are engineered to use other bulbs to compensate for bad ones.
Don't believe everything you think
Jayhawk is offline
post #3 of 4 (permalink) Old 02-21-2007, 12:23 PM
muskratbenz's Avatar
Date registered: Aug 2006
Vehicle: 1998 CLK320 (died honorably); 1999 SLK230 Sport (died dishonorably); 1987 560sec, 95 E320 Cab
Stop Lamp?
Symptoms are in line with stop lamp switch failure. It's behind the brake pedal - but you will probably have to pull a little plastic under the dash (I don't know your interior layout). The part is less than $25, and a half hour fix the first time (ten minutes, really - but slow the first time. Do search for instructs.). You can test it for functionality before buying one, by making sure it clicks smoothly in and out, and using a regular multimeter. Its about the size of a cig. lighter, with a button on end that gets pushed in by brake pedal action, and clicks out from the electrical signal by a simple two wire plug on the back. But they are known to go bad, so the odds of you having to replace someday anyway are good. Bad fault signals can be a bitch to chase down, even for a good shop, as they are often related to other electrical issues. Buy a $20 wal-mart multimeter from Wal-Mart. I didn't even own one until a month ago - or know much about using it - but it turned out to be the most useful tool in my box for diagnosing my car (208 320).
muskratbenz is offline
post #4 of 4 (permalink) Old 02-21-2007, 01:53 PM
asianml's Avatar
Date registered: Sep 2005
Check for corrosion between the contacts...
2002 Mercedes-Benz ML320 (sold)
2011 Chrysler Town & Country
2008 Toyota Camry Hybrid
2003 Yamaha V-Star 650 Classic
2002 Jaguar X-Type 2.5
asianml is offline
    "Yakuza" Sato's AMG Mercedes from "Black Rain" (starring Michael Douglas&Andy Garcia) JJB236 W124 E,CE,D,TD Class 23 10-05-2009 12:19 PM
    RNC Chairman Mehlman next to get the boot, "resigns" (aka "gets fired too") FeelTheLove Off-Topic 0 11-09-2006 09:10 PM
    Fault code 26 for a 104 eng. "what do you change" Uboater W124 E,CE,D,TD Class 5 05-31-2006 09:46 PM
    Who's fault is it that O.D. was closed at the "shop"? VirginiaDude Off-Topic 91 09-17-2004 10:11 PM
