Gas Gauge Malfunction - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-16-2007, 01:57 PM Thread Starter
Date registered: Feb 2007
Send a message via AIM to n1philli Send a message via Skype™ to n1philli
I've got a 1999 MB CLK 320 with 25k miles and my gauge reads incorrectly right after gasing up and taking off. If I let it sit for say 10 minutes, most of the time it will function properly. Would this be the sending unit or has anyone else had this problem? What is the price range I should be looking at to get his repaired?
n1philli is offline
post #2 of 2 (permalink) Old 02-16-2007, 04:45 PM
Date registered: Nov 2006
Vehicle: 88 420 SEL, 99 CLK 320 Cab-SOLD
this needs moved to the W208 forum
if you do a search you will find some info about this.
common problem with original sensors, contacts in new updated sensors are gold plated to eliminate this problem, some people had the sensors replaced with old style sensors and within a couple of years had the same problem.
I also have a 99CLK Cab and it needs both sensors as well as the upgraded wiring harness to work with the new sensors, the sensors and wiring harness upgrade will run you around $400.00 for parts, and 2.5 hrs labor. Make sure you buy Siemens VDO sensors.
Part #'s required for
202 470 39 41 Sensor VDO Manuf 06/06
208 470 06 41 Sensor VDO Manuf 06/06
202 540 41 13 Upgraded wiring harness required up to MY 2000 check VIN # before ordering
002 477 30 01 Fuel Filter Bosch
Palm Tree Mechanic is offline
    ML 320 Fuel Gauge Malfunction tredja General Mercedes-Benz 21 04-02-2016 10:12 PM
    gas gauge failure MBSL250 W163 M-Class 1 10-19-2006 07:22 AM
    Haywire Gas Gauge MorrisTigerson69 W126 S,SE,SEC,SEL,SD,SDL Class 11 07-19-2006 11:14 PM
    Gas Gauge reads 7/8 Full with a Full Gas Tank Shawn5454 W140 S-Class 5 06-13-2004 04:36 PM
    Gas Gauge in '99 ML430 MillTek W163 M-Class 6 08-25-2003 06:39 AM
