Mysterious Battery Drain - Page 3 - Mercedes-Benz Forum
post #21 of 23 (permalink) Old 10-22-2013, 02:07 AM
Diesel Benz's Avatar
Quoted: 32 Post(s)
Originally Posted by Black eagle View Post
260Mamp on a 55 a/h battery would give you some 2000 hours or 83.3 days to flat. If it drops so far as not to be able to start in a week then the drain is greater or the starter is knackered .
Things to look for; window or central locking motor on, (not shutting off at limit switches), jammed relay, Boot light on, Glove box light on.
Must be an error above. 1 A drain would make a 55 Ah battery flat in 55 hours. 260 mA is about a quarter of an amp, meaning about 200 hours which is not much more than a week. And the battery should have some juice left to start the car.
Diesel Benz is offline
post #22 of 23 (permalink) Old 03-07-2016, 01:47 PM
Date registered: Mar 2016
I know its the toughest to explain complex technical things in a way that anyone can understand, would you mind taking a stab at it for me!!! I have an 06 E320 CDI something is drawing on the battery when it is off and locked. Usually about 24 hours or so (depending on how long its been running clearly charging prior to) and it drains so far that the keyless alarm to unlock won't work. I understand the CAN and auto shutdown but narrowing down the specific draw is what I need to know how to do. So I am getting a Ammeter and assume that I start pulling fuses one by one starting with the 30's (lights and such?). Will the ammeter register the amount of draw for each fuse, should the car be on when I do this should it be fully charged etc>? Should I not even try!!! THX
Kristi is offline
post #23 of 23 (permalink) Old 03-07-2016, 01:57 PM
Date registered: Oct 2013
Vehicle: 2012 e class, roush mustang
On a 06 e320 I would check satellite radio unit or steering column unit first. But if not then yeah start pulling fuses with a amp meter. Also check central gateway for water damage
a02stang is offline
    Battery drain mjolnir C209/A209 CLK-Class 6 12-13-2011 05:55 PM
    Battery Drain...HELP Binny W201 190-Class 14 07-10-2006 08:29 PM
    Mysterious Battery Power Drain hifeverz R129 SL-Class 6 05-11-2005 09:09 PM
    Mysterious battery discharge thru CD changer Peter Guenther W140 S-Class 0 03-15-2005 04:36 PM
    Battery Drain willieg W124 E,CE,D,TD Class 3 10-25-2004 08:55 AM
