190E help. - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-25-2007, 09:47 PM Thread Starter
Date registered: Jan 2007
190E help.
Hi,
I own a 190E 2.3L inline 4 Merc.
anyway I have a question (it's my first merc, i'm 18)
I was just wondering, if you put regular gas into your premium only engine, will it stall as a consequence and won't start up, or have trouble starting up.
l0ve is offline
post #2 of 4 (permalink) Old 01-25-2007, 10:28 PM
Kajtek1's Avatar
Quoted: 1163 Post(s)
Welcome to the forum. Do a search to find something to read for coming week.
In short >> don't do it even if it seems to run OK.
Kajtek1 is offline
post #3 of 4 (permalink) Old 01-26-2007, 05:32 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 81 Post(s)
Use premium.
Mike
Michael Pillay is online now
post #4 of 4 (permalink) Old 01-26-2007, 08:42 AM
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: 2002 CLK430
No, it won’t stall and refuse to start. Not immediately at least. Your engine has knock sensors. When the knock that’s caused by low octane fuel is determined, typically Bosch systems will retard the timing and enrich the air/fuel mixture. Retarded timing and rich mixtures result in poor fuel economy, and reduced power levels. The long term effects of allowing knock to persist (if your knock sensors are faulty or the fuel is too cheap for the retarded timing to make a difference) are hammered valves and seats (corrected by a valve job) or, the always delightful holed piston (depending on the worth of the vehicle, that’s corrected by junking the car and starting over). In either instance, the false economy of saving $1.60 per tank becomes painfully obvious the owner. On the other hand, they did save a whole buck-sixty, which is almost enough to enjoy . . . . . uh . . . . . never mind that last point. A $1.60 won’t buy anyone anything.
If you’re asking because you use regular fuel AND your car constantly stalls and then won’t start, it’s probably caused by something else. How old are the plugs, the cap, the wires, and the air filter?
MarcusF is offline
    HOW TO GET hp for 190e ?????? wvh187 W201 190-Class 13 11-23-2006 09:39 AM
    Can an engine from a 190e 2.6 work in a 2.3 190E chuttu500 W201 190-Class 4 06-13-2006 06:38 PM
    190e 2.3 8v roguebotV W201 190-Class 1 12-05-2005 12:22 PM
    93 190E 2.3 - 89 190E 2.6 ALL PARTS FOR SALE !!!!!!!! sam the man W201 190-Class 0 07-03-2003 11:47 AM
    190E 2.3 -84 Guest (MBNZ) W201 190-Class 1 11-16-2001 03:25 PM
