1997 Mercedes E420 - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 01-23-2007, 07:21 AM Thread Starter
Date registered: Jan 2007
1997 Mercedes E420
I am having a problem with my blower. The climate control works fine but it will not blow! Even on MAX - it barely warms the car. Does anyone know what the problem could be? Fuse? If so, where is the fuse located?
phyllisjdj is offline
post #2 of 7 (permalink) Old 01-23-2007, 07:38 AM
Premium Member
IRLCK's Avatar
Date registered: May 2005
Vehicle: 77 450SL :: 99 SL320 sold :: 06 Sprinter 315 :: 07 Vito :: 99 E280 sold
Premium Member
I suggest you ask in the E class forum for a better chance of an answer. Could be anything from a fuse to a failed blower motor
IRLCK is offline
post #3 of 7 (permalink) Old 01-23-2007, 12:29 PM
Diesel Benz's Avatar
Quoted: 37 Post(s)
When I had a W210 car, the blower motor regulator blew up. I believe it is a common problem on a W210 (my car was MY 2000, a face lift one). Do you have automatic AC? The display was showing the adjusted blower speed but the blower was first going up and down a bit on its own and finally started blow at full speed, on its own.
The odd thing to me is that at least the face lift model did not have any fuse for the blower motor. I could not believe this but an (independent) expert confirmed this. I had to disconnect the battery because the car had to wait for the spare part over night (the blower would have run the battery flat during the night otherwise).
I've seen DIY guides for the regulator job but did not do any search at this time.
Diesel Benz is offline
post #4 of 7 (permalink) Old 01-23-2007, 01:27 PM
Vehicle: E320
Before tackling a huge job like that, check the cheap stuff, like your anti-freeze and coolant in the radiator... that can cause a lack of heat in cold weather.
EDIT: I saw you said the blower isnt blowing... if it is on MAX does the air come out fast? Or is the air just not warm?
jlink38 is offline
post #5 of 7 (permalink) Old 01-23-2007, 10:12 PM
Quoted: 37 Post(s)
This was a good clarifying question. The original post mentioned "the climate control will not blow", I assumed it does not blow air but if it does but blows cold air (but I was not 100% sure if this was a correct assumption), the cure would be something totally different from the options above (blower motor or regulator).
By the way, the blower can be accessed relatively easily, depending on one's skills, the blower/regulator job would not be a huge job (but the real fix might be different and even simpler).
post #6 of 7 (permalink) Old 01-24-2007, 07:29 AM
amcnair's Avatar
Date registered: Mar 2006
Vehicle: 1997 E420
Blower regulator is a common problem in that car. The stealership fix is around $1000 as it requires upgrading to a different blower assembly. There is a way to fix it using cheaper parts, though.
Here is a link to a lengthy post about it in the W210 forum:
http://www.benzworld.org/forums/w210...enly-slow.html
amcnair is offline
post #7 of 7 (permalink) Old 06-23-2007, 03:24 AM
'96 E320 Blower Motor Regulator
I am attaching a file that I found on another website. It seems to be an easy DIY project. You could buy a motor regulator for W-140 (S-320) and install it on W-210 ('96 E320 , my car). Part # is 140-821-83-51 , by KAE for $163.63 from autohausaz.com.
Hope this helps
ccmbduong is offline
    1997 e420 radunegru W210 E-Class 5 05-23-2006 01:04 PM
    please help ..1997 e420 a1jatt W124 E,CE,D,TD Class 1 10-30-2005 02:33 PM
    1997 Mercedes E420 Sport lbzad General Mercedes-Benz 1 12-21-2004 03:58 PM
    FS: 1997 E420 Ronald J W210 E-Class 0 02-18-2003 10:05 PM
