Trickle charger question. - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 11-29-2010, 12:17 PM
Date registered: Nov 2010
Can the battery be left connected on trickle charge . The manual says do not charge until battery is disconnected
Bob SL500 is offline
post #12 of 12 (permalink) Old 11-29-2010, 02:21 PM
Date registered: May 2004
Vehicle: '90 124.128
Quoted: 2 Post(s)
Charging Lead Acid Batteries
The Batteries "Outgas" (Give Off Hydrogen...'Member the Hindenburg?)
(We,the U.S., wouldn't sell the Reich Helium Gas; which was considered a war materiel)
So,with Batteries,there's always the danger of an UNTENDED Explosion/Fire.
Plus, the Over Voltage/Over Amperage,that many Non-Smart chargers exhibit tends to
FRY the Mucho Expensivo Electronic/Computer type Components in Modern Automobiles.
(Heaven Forfend, MB having to replace Electronics UNDER WARRANTY,'Cause you're
charging the Battery with PRC/Uro Quality chargers.)
BobSL500,
To answer your question...
Millions of people do so all the time.
AND with MB offering It's own "Branded" Smart Charger...
Call 1(800) 222 0100 and ask Customer Service the proper way to connect one
to your chassis's Battery.
[Me,I'd have a Battery Disconnect Switch on the Negative Side Between the
Battery's Negative Terminal and the Negative Cable,for use when Charging.Then the only thing capable of receiving charging would be the Battery.]
compress ignite is offline
Trickle Charger _Dennis_ W163 M-Class 10 01-18-2007 11:02 AM
Trickle charger access keyhole General Mercedes-Benz 5 11-17-2006 08:07 AM
Trickle Charger for CDI WOOCHOW W211 E-Class 1 02-11-2006 12:03 PM
Automatic Trickle Charger Telhill C208/A208 CLK-Class 0 09-07-2001 03:53 PM
trickle charger for Xmas john R170 SLK-Class 0 12-25-2000 09:26 AM
