300SD rear glass project - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-20-2007, 01:53 PM Thread Starter
johntksr's Avatar
Date registered: Jan 2007
Vehicle: 1982 300 SD
I am replacing the rear glass and seal on my 1982 300Sd. Does anyone know where I can purchase the MB Window Sealing Compound part# A 001 989 31 20? Benzine? Glycerin? All of these items are called out in the DYI sd-rear-window-seal-driver-door-seal-replacement-67-220.pdf.
Also, what type of cord is good to use when installing?
John
johntksr is offline
post #2 of 2 (permalink) Old 01-22-2007, 10:49 AM
JamieK's Avatar
Date registered: Mar 2006
Compound is available from the dealer. A little pricey at 22.50 a tube, but good stuff. You can get by without the glycerine and benzine. The benzine is for cleaning the sealing surfaces (you can use mineral spirits), and the glycerine is for lubing the rubber so it will install a little easier. Dishwahing soap works good. As for the cord, I went to Lowes and bought 100' of *I think* 3/16 or 1/8 inch rope. This will do several glasses.
Jamie
But then again, I could be wrong.........
Where is everyone? Find out here (and let everyone know where you are, too)...
http://www.frappr.com/w123club
JamieK is offline
    NEWBIE...300SD as first car restoration project mulamutti W126 S,SE,SEC,SEL,SD,SDL Class 6 09-21-2008 05:40 PM
    Rear glass trim. Jammerkiller W201 190-Class 17 10-05-2006 09:23 PM
    W126 rear door, rear window glass, window roof motor, door cards, rear plastic panels, ECU Peter Seow For Sale/Wanted/Trade/Giveaway 0 12-27-2005 07:07 AM
    Rear Glass removal Floridadave R/C107 SL/SLC Class 4 12-07-2005 07:06 PM
    getting a project 300sd, need lots of advice on where to get parts etc. Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 1 10-30-2001 05:48 PM
