Missing on idle 320SL R129 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-18-2007, 12:24 AM Thread Starter
Date registered: Jan 2007
Vehicle: '92 SL320, '94 E220 Coupe, '77 SL450, '00 C180, '97 Ford Mondeo, '73 Morris Marina!!
I would be very grateful to recieive any ideas on the following problem.
The car is a 1992 R129 320SL. It idles and runs perfectly except for an intermittant fault. When warm (after 5 mins) it may missfire at idle or at low revs (ie in traffic or stationary). When the revs rise it will clear itself and will run fine at higher revs on the motorway.
The misfire is a random blip down on the revs..... not unstable idle or high revving.... otherwise the idle is stable the rest of the time.
I have started by changing the plugs (and gapped them properly), new plug leads, and distributor cap / rotar arm. This has made no difference, but the fualt is hard to find as it seems to disappear when the bonnet is lifted and the engine just idles fine!
I haven't yet tried changing the coil..... might this be a good next step?, or do you have any other ideas?.
Many thanks
Benzboxer is offline
post #2 of 2 (permalink) Old 02-11-2010, 10:13 AM
Date registered: Feb 2010
missfire problem
i had a similar problem with a 1995 s500.the missfire happened only when the engine warmed up.the problem was caused by the two distributors.they were almost wet from damp and condensation.when they were dried out the engine
ran perfectly.i never found out what caused the problem in the first place.i hope this helps.
regards;boris yadek.
borisyadek is offline
    high idle am i missing something Naomilla2.0 W126 S,SE,SEC,SEL,SD,SDL Class 11 03-28-2012 02:20 PM
    1977 450SLC rough Idle and Missing - HELP PLEASE finleymac R/C107 SL/SLC Class 11 09-29-2008 06:48 AM
    Need to find missing part of my idle control Cyberbach W123 E,CE,D,CD,TD,TE Class 10 06-08-2006 03:39 PM
    Pinging-Shuddering-Missing@idle KMX3060 W126 S,SE,SEC,SEL,SD,SDL Class 2 08-10-2004 08:01 PM
    320sl questions Guest (MBNZ) R129 SL-Class 2 04-19-2001 08:34 PM
