300SL: rough running, I'm stumped. - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 01-13-2007, 02:35 AM Thread Starter
Date registered: Jan 2005
Hello,
I'm in big trouble with my "old" car and hope I can find some help here. This may seem so crazy, you'll think I'm making it up. Here goes ...
1993 300SL. About 105k miles. Runs flawlessly, except ...
Car is no longer a daily driver. If it sits for a few days, this happens: Starts normally. Runs great for perhaps 15 minutes. Then it begins to miss, then to miss badly. After a few minutes of this it will barely keep running, to the point that it can't climb much of a hill.
After about 10 minutes of this, it starts to recover, and in another 5 minutes or so it's back to normal. After this, it stays completely normal and runs fine unless it's left to sit for a few days. Then the same behavior repeats.
Any ideas much appreciated. I'm developing a twitch here.
Thanks,
Dennis
Dennis-SL is offline
post #2 of 7 (permalink) Old 01-13-2007, 06:31 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 70 Post(s)
Fuel filter OK?
flyboyike is offline
post #3 of 7 (permalink) Old 01-13-2007, 07:49 AM
mybenz123's Avatar
Vehicle: w123 300tdt
Condensation in the cap maybe?
Maybe time for a new cap and rotor.
Louis.
mybenz123 is offline
post #4 of 7 (permalink) Old 01-13-2007, 01:15 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 752 Post(s)
A good old-fashioned tune-up would be a great place to start, IMHO -- plugs, wires, cap, rotor, air filter, fuel filter -- and see if that helps. Assuming of course, that you haven't already done that pretty recently.
GeeS is offline
post #5 of 7 (permalink) Old 01-13-2007, 03:38 PM Thread Starter
Thanks to everyone who replied. I should have said that the "tune-up" level stuff should be OK. The really wierd part is the ebsolutely predictable cycle of runs good - barely runs - runs good over about a 1/2 hour period after cold start. And only if the car has had a couple of days off.
I feel as though it may be somehow related to the engine warming up, but I'm not sure how to run with that idea. The temp gauge comes up normally, and coolant level is OK.
Thanks again,
Dennis
post #6 of 7 (permalink) Old 01-13-2007, 03:58 PM
Date registered: Dec 2006
Check the catalitic converters....As strange as it may sound my old Caddy had the same problem and is was a plugged converter.
nosferatu is offline
post #7 of 7 (permalink) Old 01-21-2008, 03:05 PM
Date registered: Feb 2005
Vehicle: r129 320 sl V6 year of manufacture 1999 auto
temp sensor
same prob on my 92 300sl 24v been told its most likely temp sensor miss reporting to cpu
need to know were it is to check it ??
muso58 is offline
92 300SL Day Time Running Lights Turn on dgoodwin R129 SL-Class 15 12-31-2007 07:40 AM
i'm stumped, car runs great but has a bad rough idle problem. HELP ProV1x W210 E-Class 11 12-10-2006 06:04 PM
300sl running fault lynne R/C107 SL/SLC Class 4 10-18-2006 10:42 PM
300sl running rough cured YES YES oh YES perry131313 R/C107 SL/SLC Class 2 11-15-2005 02:27 AM
rough running phoenix7 W124 E,CE,D,TD Class 5 12-11-2003 07:44 PM
