what exactly does "EC" (Economy) button do? - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 01-08-2007, 08:28 PM Thread Starter
ProV1x's Avatar
Date registered: Jul 2006
Quoted: 2 Post(s)
quick q, is the EC button the same as "AC" button in other cars? so during the wintertime, i can leave the EC on the whole time and it'd be ok right. i havent noticed any fuel economy differences with EC on however
Gone but not forgotten:
2003 Honda S2000
1999 BMW 540i sport
1995 BMW M3
ProV1x is offline
post #2 of 14 (permalink) Old 01-08-2007, 08:44 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hey, Pro.
Didn't you get the novel (aka owner's manual) with your car?
The EC button in most cases will preclude the air conditioning compressor from engaging, which will increase fuel economy depending on other conditions.
However, if you call for the compressor in other ways (such as engaging the button for the front window defrost) it will override the EC button and operate normally.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #3 of 14 (permalink) Old 01-08-2007, 09:21 PM
marlinspike's Avatar
Date registered: Feb 2005
Vehicle: 1985 380SE
EC is the stuff that doesn't need a compressor: heater and "vent" on other cars.
marlinspike is offline
post #4 of 14 (permalink) Old 01-09-2007, 12:41 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Actually, the default is to always use the a/c compressor, as it provides dehumidification which helps with defrosting and defogging..
If you can do without that, you can optionally select EC and get a bit better economy by not using the compressor.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #5 of 14 (permalink) Old 01-09-2007, 01:00 PM
Vehicle: 1993 300SEL (Sold) 2001 530i (Sold) 2008 C250
Quoted: 7 Post(s)
I don't know what the AC systems on other MB's are like but I've been told by a few car dealers that running the EC mode all the time can cause the whole AC system to degrade as tehy need running .
NZ Benz is offline
post #6 of 14 (permalink) Old 01-09-2007, 01:35 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Not sure if this is equally critical with modern AC systems, they have ceramic seals which do not start to leak equally easily as the older ones.
The older ones (at least) should be run frequently, some say once per month at least, some say more often. This keeps the seals in good condition.
The modern ones do not have an electrically controlled drive clutch but the compressor runs always. They use a different way to control the compressor functionality, some valves switch the circulation on and off, don't know the details.
I assume that this advice is still useful for all generations. Could be that it is not only the compressor seals that are happy when they get some exercise every now and then.
There is an interesting MB document about the AC systems on all current MB models.
Diesel Benz is offline
post #7 of 14 (permalink) Old 01-09-2007, 01:43 PM
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
I believe EC is the same as the VENT button in lesser vehicles...
Don't believe everything you think
Jayhawk is offline
post #8 of 14 (permalink) Old 01-09-2007, 08:58 PM
Quoted: 7 Post(s)
I just run mine all the time anyway that way I can set the temp I like for all year round regardless of whats going on outside.
NZ Benz is offline
post #9 of 14 (permalink) Old 01-09-2007, 09:05 PM
Jayhawk's Avatar
Your vent or a/c? I leave my temp on all the time. The a/c compressor only runs when the temp is warm outside. I just never think about it 24/7, 365 days a year. It is just always very comfortable year round.
Jayhawk is offline
post #10 of 14 (permalink) Old 01-09-2007, 10:46 PM
Quoted: 7 Post(s)
The AC.
NZ Benz is offline
    Malfunctioning ""REST" Button on A/C Control Panel/Batt Drain Mr. Farknocker W140 S-Class 12 06-30-2016 04:20 PM
    Climate Control "Stuck on EC (Economy)" contilon W210 E-Class 17 09-13-2009 11:06 AM
    ESP Switch (a.k.a. "The Danger Button") BryanSDavis R170 SLK-Class 4 11-20-2006 10:58 AM
    Found something new again about the ML. Earlier today, I pressed the "lock" button on the Darkmann W163 M-Class 4 08-26-2002 06:09 AM
    Log Out - - Drew, you need a button on the forums like at "Home Page". Thanks! [:)] Jüri. W163 M-Class 2 08-07-2002 05:59 AM
