Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > General Mercedes-Benz
Old 01-03-2007, 01:48 AM   #1 (permalink)
Date registered: Jan 2007
Vehicle: 2002 honda civic
Certified mercedes benz Tech here
Just thought I would say whats up. I am a certified mercedes tech in the miami, ft. lauderdale area and still work on mercedes. If you have any questions let me know or if you need any work done.
Streetglower is offline   Reply With Quote
Old 01-03-2007, 03:15 AM   #2 (permalink)
cascade's Avatar
Date registered: Nov 2006
Vehicle: 1991 AMG 560SEC, 130k (Pearl black/black); 2008 Subaru Outback PZEV, 6,700 (actual) miles.
Hi and welcome, which models do you specialize in? Diesel, gasser, new ones needing the OBD II diagnosis, old ones like the W115 and w108, or youngtimers like the 123, 107, 124 and 126?
Have you seen any of the W210s with the spring perch failure problem? Do you hate working on the W140 and W220?
cascade is offline   Reply With Quote
Old 01-03-2007, 04:01 AM   #3 (permalink)
Vehicle: 2002 S500 Silver - Sport Package
Question? Receiving tire pressure monitor warnings on my 2002 S500. The car sat up for about 15 days and drained the battery. Bought new battery, it was time. Now receiving all these warning codes. Took to dealer, fixed most of the codes but now tells me the EIS Module is out and won't let him trouble shoot the tire pressure monitor. Any thoughts?
sbmyers is offline   Reply With Quote
Old 01-03-2007, 05:33 AM   #4 (permalink)
Rear diff leak of ML 430
Hi,
Welcome !
The rear differential on my ML 430 (2001) is starting to leak ( very minor leak I suppose ). I am planing to check the fluid level soon, but Is this possible and if so, has anyone repaired this type of leak succesfully?
There should be a vent tube / breather or similar, but where I can find it ?
Thanks a lot for any help
PUPU is offline   Reply With Quote
Old 01-03-2007, 08:00 AM   #5 (permalink)
Musikmann's Avatar
Thumbs up Welcome Streetglower!
It's GREAT to have you on the forum SG, and thanks in advance.
It shouldn't take you long to "surf" around on the various threads here, and you should see a LOT of problems for which you can offer advice.
Good luck with finding some service customers too,
M
Old 01-03-2007, 03:39 PM   #6 (permalink)
I work with everything diesel or gas. mainly the newer models, 220, 203, 209, 211, 163, 164, 251. have some experience with 208 and 210. 220 isnt bad, they seem to have too many problems with the TPC.
Old 01-03-2007, 03:40 PM   #7 (permalink)
do you know what codes are being thrown for the TPC?
Old 01-03-2007, 03:42 PM   #8 (permalink)
Originally Posted by PUPU
Hi,
Welcome !
never resealed the diff on a ml, but there should be a plug on the diff that if you remove you can stick your finger in and check the level. the level should be at the bottom of the fill hole. And yes these leaks are repaired all the time. they will usually drop the diff and reseal the cover if thats whats leaking. usually at the same time they will replace the side seals.
Old 01-03-2007, 04:18 PM   #9 (permalink)
nsw
Date registered: Oct 2004
Vehicle: 04 E320 4Matic
Very nice to have someone like you here! Hope you are familiar with my model (see left).
Happy New Year!
nsw is offline   Reply With Quote
Old 01-04-2007, 03:31 AM   #10 (permalink)
Unfortunately, I don't know what codes are being thrown out by TPC. I gave the go ahead to replace the EIS Module, which I've been told would allow the dealer to further trouble shoot the TPC. Just trying to confirm if this all makes sense.
My 2002 S500 only has 33k miles, so I'm a bit surprise at this battery drain and TPC problem.
"Mercedes Benz" Certified frankief General Mercedes-Benz 13 12-03-2006 02:52 PM
2 Malfunctions on a 1 week old certified benz lordpain W220 S-Class 1 07-09-2006 10:28 AM
want a new/certified pre-owned benz? ravenr1 General Mercedes-Benz 7 03-13-2006 09:10 AM
Mercedes-Benz Tech Session - Toronto - April 17th amgbnz Events 1 04-19-2004 07:47 AM
