Certified mercedes benz Tech here - Page 10 - Mercedes-Benz Forum
post #91 of 139 (permalink) Old 01-26-2009, 05:38 PM
joedrt99's Avatar
Date registered: Nov 2008
Vehicle: 2003 c230 kompressor
Post
2003 c230 kmopressor...i disconnected the battery and lost control of the sunroof. it tries to open but will only click.. i heard i have to re-sync the window. can you tell me the steps to do this?
joedrt99 is offline
post #92 of 139 (permalink) Old 01-26-2009, 08:27 PM
Date registered: Nov 2006
Holdthe sunroof button in the "vent "position(up) for about 5 seconds and it should resynch itself
BenzTek510 is offline
post #93 of 139 (permalink) Old 01-26-2009, 08:56 PM
joedrt99's Avatar
Post
thanks for the information ill will try this when i get out of work tonight
joedrt99 is offline
post #94 of 139 (permalink) Old 01-27-2009, 04:50 PM
xeon problem
my driver side xeon only keeps blinking on and off real fast can u please help it does it for a while then stop and start back it did it the first day i got the car and never did it again untill now 3months later
johndoe11203 is offline
post #95 of 139 (permalink) Old 01-27-2009, 07:27 PM
deep3175's Avatar
Date registered: Jan 2009
Vehicle: 95 benz E320 wagon
I have charging issues I have a 86 300e and the electrical system has been giving me problems I'm not getting a charge had the alternator tested and it was fine so I'm stuck on what to do next
deep3175 is offline
post #96 of 139 (permalink) Old 01-28-2009, 05:39 AM
Date registered: Sep 2008
HI. I have a 2001 clk 430 thats not getting spark> Its getting fuel and injector pulse. I tried a new crank and camshaft postion sensor. Any ideas
philh71 is offline
post #97 of 139 (permalink) Old 01-28-2009, 06:27 AM
Bill A's Avatar
Quoted: 27 Post(s)
Streetglower, I bet you were never this popular in school. May your typing fingers be strong and your wit sharp grasshopper.
Bill
Bill A is offline
post #98 of 139 (permalink) Old 01-28-2009, 06:33 AM
deep3175's Avatar
I don't know if your car has it but I was having the same problem and I changed my ignition control module and that fix the problem so I would have that tested. They are expensive for a new one, you can find rebuilt ones I was fortunate enough to find one in a junkyard for 20 bucks but when doing that your taking a chance on it being bad also.
deep3175 is offline
post #99 of 139 (permalink) Old 02-28-2009, 08:40 AM
Date registered: Mar 2007
2001 C320
mb tech,
Originally Posted by Streetglower View Post
Just thought I would say whats up. I am a certified mercedes tech in the miami, ft. lauderdale area and still work on mercedes. If you have any questions let me know or if you need any work done.
hi, pleasee help me.
The problem is when the car is off and doors closed and locked, the instrument display stays lite. It will continue to stay on, thus draining the battery.
What should I do?
RwdforLife is offline
post #100 of 139 (permalink) Old 02-28-2009, 10:39 AM
Date registered: Jan 2007
Question for Streetglower
Streetglower,
I have replaced the rear wheel bearings on my 80 300 SD. I'm replacing the
half shafts as well. Any idea where I could find out the proper torque or
way to attain the proper preload on the bearings? I have the slotted socket
that tightens the nut which retains the hub and bearings. Thank You, Joel.
alaska benz is offline
Closed Thread
    "Mercedes Benz" Certified frankief General Mercedes-Benz 13 12-03-2006 02:52 PM
    2 Malfunctions on a 1 week old certified benz lordpain W220 S-Class 1 07-09-2006 10:28 AM
    want a new/certified pre-owned benz? ravenr1 General Mercedes-Benz 7 03-13-2006 09:10 AM
    Mercedes-Benz Tech Session - Toronto - April 17th amgbnz Events 1 04-19-2004 07:47 AM
