How to Check the working condition of Alternator and Battery in a 230E car - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 12-31-2006, 05:48 AM Thread Starter
Date registered: Dec 2006
Post How to Check the working condition of Alternator and Battery in a 230E car
Please explain How to Test the Alternator and Battery in a 230E car.
Venkatachalam is offline
post #2 of 2 (permalink) Old 12-31-2006, 06:48 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 78 Post(s)
If you can remove them, Advanced Auto/ Autozone can test them for you. If not, You will need a multimeter. If the battery has been charged up, the voltage should be slightly above 12V. I am assuming you have a 12 V battery. I am not familiar with your exact model. Anyway, check the voltage with the car not running. Voltage should be around 12 V. Start car, check voltage. Voltage should be 14V to 15V. If it is not, you likely have an alternator problem. If it is the alternator, find a local starter alternator shop to rebuild it. Much cheaper than getting a new or reconditioned unit. Where are you located?
Michael Pillay is offline
    It is working!!! Modular Control System is not working after I changed battery di_mb W163 M-Class 0 12-27-2006 07:04 PM
    w124 - 230e - 92, Battery question Piolo W124 E,CE,D,TD Class 3 03-08-2006 06:18 AM
    Battery or Alternator?? Benzola SD W126 S,SE,SEC,SEL,SD,SDL Class 2 11-23-2003 07:33 PM
    Battery or Alternator? aerosly W126 S,SE,SEC,SEL,SD,SDL Class 6 08-29-2003 06:10 PM
    Battery or alternator? cjscopp W126 S,SE,SEC,SEL,SD,SDL Class 8 05-03-2003 01:26 AM
