New 4 stroke engine - Page 42 - Mercedes-Benz Forum
post #411 of 449 (permalink) Old 08-21-2014, 05:03 PM Thread Starter
Feliks Andrew's Avatar
Date registered: Dec 2006
Vehicle: Mercedes 508 D
Here historical figure .. then only the best solution was graph paper .. Figure was every day for 1 month used, when did this lathe crankshaft. The crankshaft has five supports and four crank, 90 degrees .. starting weight of the material (iron containing 5% cobalt) was 80 kg (160 lb) is the world's first practical crankshaft timing ..
Andrew
Feliks Andrew is offline
post #412 of 449 (permalink) Old 08-21-2014, 06:35 PM
Date registered: Jul 2005
Quoted: 1057 Post(s)
Okay, at his point I have read all your posts for years. Some of it is original, but most of it is just lifted and copied to here from many other sources you have found online.
So when are you going to get back to a re-invented 4 stroke internal combustion? We have seen enough about the already well known laws of physics about airflow.
kurtismayfield likes this.
Noodles is offline
post #413 of 449 (permalink) Old 11-06-2014, 03:37 AM Thread Starter
Greetings to all from the Engine Expo 2014 in Novi Detroit ....
I'm worried, because you will be some news about this new engine somehow obtain. As I wrote above, only 25% of the engines messages may come in handy .. The rest 75% you have to re-learn ..
Regards Andrew
post #414 of 449 (permalink) Old 11-18-2014, 02:24 PM Thread Starter
Here are the materials you can download a PDF of the conference .. I am at the end of the first day, as it was in the schedule
Engine Expo North America 2014 Conference Proceedings
Andrew
post #415 of 449 (permalink) Old 11-18-2014, 05:32 PM
Glad it is going well for you. Just one question Andrew.
How is it that you sre at the conference in North America, but your latest post is from a Polish IP address? Do you have a private jet and commute daily to the conference, proxy server, or VPN based IP?
Noodles is offline
post #416 of 449 (permalink) Old 11-19-2014, 08:40 PM
Kajtek1's Avatar
Quoted: 1226 Post(s)
I believe what Andrew meant was that his project was presented at the end of day 1 of the conference and you can see it once you click the links.
The conference ended 2 weeks ago.
Kajtek1 is online now
post #417 of 449 (permalink) Old 11-20-2014, 07:05 AM
Now that would make sense. It sounds like it was a fruitful conference for Andrew.
Noodles is offline
post #418 of 449 (permalink) Old 11-20-2014, 07:51 AM
Kajtek1's Avatar
I hope so.
It is very interesting concept, but 30 + years in prototype faze is not making you holding your breath.
post #419 of 449 (permalink) Old 12-17-2014, 12:56 PM Thread Starter
Santa Claus is always something for Christmas will bring a gift. This year a new type of Venturi nozzle ..
Christmassy greetings
Andrew
post #420 of 449 (permalink) Old 12-21-2014, 10:04 PM
benzofour30's Avatar
Date registered: Feb 2004
Vehicle: 2014 G63, 2015 RX350, 2012 Harley Vrod,
Quoted: 5 Post(s)
Fajnie widziec rodaków(Polacy) tu na mbworld, a zwłaszcza tych co do czegoś donżą i maja nowe pomysły.
Pozdrawiam i życzę samych sukcesów.
Edited by Noodles:
Very basic translation.
It's nice to see you compatriots (Poles ) mbworld here , especially those about something Donz and have new ideas.
Best regards and wish you every success.
Please try to keep posts in English. I understand you are reaching out in a warm way to Feliks and you also meant meant to say benzworld not mbworld.
benzofour30 is offline
Closed Thread
    To stroke or not to stroke? basix W201 190-Class 3 12-04-2007 12:47 AM
    BABY HAD A STROKE TODAY !!!!!! Smokiesman W124 E,CE,D,TD Class 9 10-28-2004 07:49 AM
    A Stroke Of Luck Terabyte W123 E,CE,D,CD,TD,TE Class 4 08-04-2004 09:19 PM
    Engine Stroke Kit pcm0928 W202 C-Class 1 07-24-2003 08:00 PM
    Bore & Stroke pcm0928 W202 C-Class 0 09-14-2002 07:13 AM
