New 4 stroke engine - Page 4 - Mercedes-Benz Forum
post #31 of 449 (permalink) Old 08-12-2008, 05:44 PM Thread Starter
Feliks Andrew's Avatar
Date registered: Dec 2006
Vehicle: Mercedes 508 D
Next about 550 MW power engine project:
550 MW
Regards Andrew
Feliks Andrew is offline
post #32 of 449 (permalink) Old 08-22-2008, 06:00 AM Thread Starter
Originally posted by Feliks
For hi power system my version this good idea:
Better is good enemy !!
New rod differential at animations Solid Works when one axle stop:
http://www.new4stroke.com/differ%20stop.wmv
Andrew
post #33 of 449 (permalink) Old 08-27-2008, 02:59 AM Thread Starter
And GIF animations:
Regards Andrew
post #34 of 449 (permalink) Old 09-06-2008, 05:51 PM Thread Starter
I find a beautiful array :
At last something happens .
In my oscillating dynamo I help cellular telephone IC Lm 2621.
May be cellular telephone need advanced mechanic??
If put in cellular telephone mechanic automatic movement,using in mechanic clock, and miniature electric generator drive it, we don't need charge cellular telephone.Phone will be loaded on our result of traffic, obvious as there will be in our pocket
Some parts and principle work of automatic movement:
Perhaps, we must use e.g. 6 such systems, in order to can be charge phone goods .?
Same philosophy : no one big , many little.
May be Swiss precision it will astonish again .
Regards Andrew
My propose for yacht: On highest point of mast instead of flag,for example,box belongs to place with such array: 20 pcs X 20 pcs X 60 pcs sisrtems (50cm x 50cm x 30 cm). All 24000 sistems. And I think, so enough for made elelectric energy for yacht. Without any fuel.
post #35 of 449 (permalink) Old 09-09-2008, 03:07 AM Thread Starter
There is possible build closest house fiberglass mast too ,and we insert dynamo in this highest place. When wind blows this e.g 15 meter mast too have some movement.
It's first double medium energy use -- wind + gravitation
Without barrier for birds , and no sound effect. And looks better
Andrew
post #36 of 449 (permalink) Old 09-12-2008, 04:46 AM Thread Starter
My propose new
Differential Gear. It's first design.
Without any cogged gear, and if we will employ oiled lubrication solid ball bearing (closed), then work is possible without oil oiling .Polyurethane HD belt.
I am some, that such will work without that noises differential .
Regards Andrew
I think,so efficiency this dsign are better old version.
Weight too little.
post #37 of 449 (permalink) Old 09-27-2008, 05:47 PM Thread Starter
My friend ( architect and musician) has said that it distrusts springs." Because if it can crack, then sometime it will crack sure." I agre with his think:
And my vision Pack of oscillating dynamo:
Why I don't like spring:
Yes, discus about advantages and disadvantages of spring a re start
Some video, what spring of poped can make :
http://www.engr.colostate.edu/high_s...pm_3000fps.wmv
http://www.engr.colostate.edu/high_s...pm_1000fps.wmv
I thik, so pistons valve , and rod eliminate this "play sprig".
Mass too is better solutions.
Regards Andrew
post #38 of 449 (permalink) Old 10-15-2008, 04:45 PM Thread Starter
Farthest development at one pivot stand differential animations, but this time about 180 degrees removed rod. Permutation is possible about 90 degrees definitely too.My be It's help if torque will not have a linear relationship But which setup will be better, as yet, I do not know
To develop simile Torsen torque biasing and traction management too.
You see this animations?
Andrew
post #39 of 449 (permalink) Old 10-16-2008, 12:26 AM
~BANNED~
full house's Avatar
HI!
found it too . . . there were lots of strokes being done but I don't think those are safe. Better stick to manual, I don't want to get hurt! lol
full house is offline
post #40 of 449 (permalink) Old 10-27-2008, 04:39 AM Thread Starter
But it, you know it definitely :
Regards Andrew
Closed Thread
    To stroke or not to stroke? basix W201 190-Class 3 12-04-2007 01:47 AM
    BABY HAD A STROKE TODAY !!!!!! Smokiesman W124 E,CE,D,TD Class 9 10-28-2004 08:49 AM
    A Stroke Of Luck Terabyte W123 E,CE,D,CD,TD,TE Class 4 08-04-2004 10:19 PM
    Engine Stroke Kit pcm0928 W202 C-Class 1 07-24-2003 09:00 PM
    Bore & Stroke pcm0928 W202 C-Class 0 09-14-2002 08:13 AM
