New 4 stroke engine - Page 39 - Mercedes-Benz Forum
post #381 of 449 (permalink) Old 12-25-2013, 07:16 PM Thread Starter
Feliks Andrew's Avatar
Date registered: Dec 2006
Vehicle: Mercedes 508 D
Here, a model project of The Spoon Red Baron Tractor. Human powered Dedalus, a comprehensive Weight about 100 Kg. It has been proved that, at a power of 0.3 Kw can take place before long flights .. Here my project model can be 100 times lighter, or to his same drive just 300 watts / 100 = 3 watts .. I think that such a model will be able to produce up more, so I called him a Tractor, he can still pull a glider behind him ..
Andrew
Feliks Andrew is offline
post #382 of 449 (permalink) Old 12-27-2013, 05:17 PM Thread Starter
With time on holidays, this Yoda even sent a picture from NASA Simulator, explaining many things ...
Oh yes you can see that the lift force (lift) is three times greater than the resistance (drag) the wings .... The diagram shows that the velocity profile at 25% is almost 3 times higher on average .. The purple line on the graph .. The green line is the wind speed .. Yellow is the speed of the lower side profile .. Wind speed is 15 km / h ... At the start of a profile is almost 50 km / h ... Such profiles should have the Red Baron Windmill (spoon too) ..
If the speed is increased by three times, then by using dual such a system, we can get about 9 times Increased speeds the wind that blows on the system .. it is worthwhile to do so .. Well of course, because in the formula for Velocity windmill power plays up to the third power, it is possible to obtain power .. no examples listed here .. for 5 m / s .. Windmill with a diameter of 100 meters are 2,000 KW us .. Now if we take a larger representation rate 9 times that or 45 m / s, it is already at 10 meters in diameter windmill get 2,300 KW. ie the same windmill is ten times smaller .. the rest of the structure is virtually immobile and will not be higher than 50 meters .. as follows from theoretical calculations.'s say the length of the building is 100 m, which can fit 10 windmills in it .. theoretically get 23 MW at a wind speed of 5 m / s.
But of course we can use the Windmill Red Baron ..
Andrew
post #383 of 449 (permalink) Old 12-30-2013, 02:42 AM Thread Starter
If you do not believe my calculations, it can send a check to the CERN ..
Andrew
post #384 of 449 (permalink) Old 01-04-2014, 09:22 AM Thread Starter
So embarrassing new year to start something pleasant .. Here, the recording band Blue Black and Ada and Wojtek cover what is served up at concerts in the Soviet Union in 1973, passing from the scene, the better, "my Friend" than the "cold war" .. ..
And I think I succeeded ..
Ada unfortunately died 1 January 1991.
Here, too, if someone did not know that Beatles song and accompaniment of the Kings ...
Andrew
post #385 of 449 (permalink) Old 01-13-2014, 03:10 AM Thread Starter
Well, here , a movie that shows that " spoon effect" is possible to obtain a large area, no such model of the wing , set " bellies " to each other. Between the wings , air is blown using an ordinary hair dryer .. The second part of the film , you will see that blowing this way only one wing , we can feel the hand , there is some lift of the wing . Simply it is so microscopic that it can not feel , despite the fact that once we're blowing on the wing , then do not . I do not feel any difference. The reason is also that the air dryer has a very low speed, and it is relatively very little ..
However, as we hold as two wings . set ' bellies to each other, and kept at one end , the other end , a very intense vibration , bouncing off each other, as a result of blowing the hair . the film do not really see these vibrations because their speed is high , as the camera does not records so quickly. records and revealed that the image of " waving wings. " In a time while also heard the " clack " of themselves striking the wings .. so attractive force them to each other must be large, as seems the powerful sound of beats between them. wing to descend , and then diverge , and again, there are withdrawal force with each wing , and so the circle. But fairly quickly , despite the relatively large area of ??the wings in relation to a small air stream flowing between them ..
In any case , it is this force several times to each side of the Astringent greater than the lift of a single wing , which you can not even feel that there is in these conditions ..
Flat Venturi designer Andrew Feliks - YouTube
Andrew
post #386 of 449 (permalink) Old 01-13-2014, 05:33 AM
CrifJohnson's Avatar
Date registered: Sep 2013
Vehicle: no
Hi,
Yeah the calculation prove that is can be happen. But apart from these calculation the design and the weight balance against and with gravity put important concern.
CrifJohnson is offline
post #387 of 449 (permalink) Old 01-14-2014, 04:22 AM Thread Starter
Originally Posted by CrifJohnson View Post
Hi,
Whether these your concerns stem from a calculation, or merely that it was not so far done so?
post #388 of 449 (permalink) Old 02-02-2014, 03:33 PM Thread Starter
Underground sarcophagus must be the first in Fukushima.
Andrew
post #389 of 449 (permalink) Old 02-05-2014, 05:01 PM Thread Starter
Here, as the tunneling doing in the world, quickly and as cheaply ...
Andrew
post #390 of 449 (permalink) Old 02-11-2014, 01:40 PM Thread Starter
So, here is the sea, the British shows them for years, as same storms the fenced off shore .. which formed small pool ... Now the water accumulated there, you can refer back to the sea, but by the turbine, which will be make electricity .. The simplest solution ... A little more civilized, I invent .. here they are. Even with the smaller waves works .. In Scotland, the annual average wave height is 3 m .. And the car would probably put a nuclear engineers to examine how quickly the corrosive materials used in its construction .. In the video you can see that even a police officer imagines that in such a way that you can produce energy ..
https://www.facebook.com/photo.php?v=817204154961489
Andrew
Closed Thread
To stroke or not to stroke? basix W201 190-Class 3 12-04-2007 12:47 AM
BABY HAD A STROKE TODAY !!!!!! Smokiesman W124 E,CE,D,TD Class 9 10-28-2004 07:49 AM
A Stroke Of Luck Terabyte W123 E,CE,D,CD,TD,TE Class 4 08-04-2004 09:19 PM
Engine Stroke Kit pcm0928 W202 C-Class 1 07-24-2003 08:00 PM
Bore & Stroke pcm0928 W202 C-Class 0 09-14-2002 07:13 AM
