New 4 stroke engine - Page 38 - Mercedes-Benz Forum
post #371 of 449 (permalink) Old 09-17-2013, 12:59 PM Thread Starter
Feliks Andrew's Avatar
Date registered: Dec 2006
Vehicle: Mercedes 508 D
Once at the end of 1969 I swapped models RC (tube!) On sound engineering and health ectronic instruments in this music band ... ..
Andrew
Feliks Andrew is offline
post #372 of 449 (permalink) Old 09-18-2013, 03:05 PM Thread Starter
Similar to Kosciuszko Mound ... Like so Mound in Krakow fell to the Vistula and obstructed it, we would have Tsunami from the mainland ... do not need any earthquakes ... Once the sequence of events predicted arguing against nuclear power ...
Maybe it is worth to seriously take this example, because there is always such a miracle as the heavens here we will fund .. I strongly tell against such power plants. You can not, as you believe in miracles ...
Andrew
post #373 of 449 (permalink) Old 09-18-2013, 03:06 PM Thread Starter
post #374 of 449 (permalink) Old 09-28-2013, 08:19 AM Thread Starter
post #375 of 449 (permalink) Old 11-01-2013, 05:53 AM Thread Starter
So now Papa certainly hear it well....[*][*]
ALEX "Papa, Can You Hear Me" - YouTube
post #376 of 449 (permalink) Old 11-11-2013, 06:55 PM Thread Starter
Well after that our mourning have something on the front ..
No. So designing a good amplifier that amplifies much is not simple and easy ..
Here, it's about the type amplifier wind instruments. On this page, the instruments are charts that say the sound intensity can vary over a range frequencies with as much as 6 dB.,. This large difference is due to raw material from which it is made ??instrument, with the same shape.
Acoustical Society of America - How Brass Instruments are Built
If we want to get a change of size (volume) using a classic amplifier-loudspeaker system is to get the 6 dB of sound, we need to use as much as 4 times greater electrical power, not, for example, 50 watt, well, up to 200 watts .. Up so much growth in sound, as it turns out, it gives us the right material for the trumpet ..
https://ccrma.stanford.edu/CCRMA/Cou...00000000000000
Home theater, decibels, speaker setup, speaker sensitivity, surround sound.
Yes, we can easily lose with this energy gain, as we will use the wrong material ....
Now the one of the simplest experiments of physics ..
It is a "kitchen an experiment." We take two tablespoons can be of tea or soup. Take them by their ends and bringing together bellies ... Between tummy wpuszczmy very small stream of water. I bet that you will not be able to maintain a 2 mm gap between them ...
We can also repeat the experiment horizontally, so that the speed of the fluid force is created ..
Andrew
post #377 of 449 (permalink) Old 11-15-2013, 05:32 AM
Date registered: Nov 2013
Vehicle: mercedes cls 63 amg
Think green with the latest Mercedes CLS 63 AMG ECO System
Mercedes CLS 63 AMG – Ecological | mercedescls63amg.com
ivelina87 is offline
post #378 of 449 (permalink) Old 11-18-2013, 01:24 PM Thread Starter
Well, finally, after a year, I received a cut down water, the elements of Plexiglas to model "Halfrotate Engine 1000 cc volume" ....
He is set to keep on hand, has 100ccm cylinder capacity .. 4 x 25.4 cm ^ 2 surface and 1 cm thick ..
to 1000 ccm this height h = 10 cm ..
to 3000 ccm this height h = 30 cm .......
First impressions: the piston surprisingly easy to change direction when moving your fingers inside the "barrel" .. I think very highly rotary engines will also be
possible to build ..
Andrew
post #379 of 449 (permalink) Old 11-24-2013, 03:26 AM Thread Starter
For this size Windmill Red Baron, surely the need for such an actuator driving a generator .. You know that place slot, achieved speed by air is three times greater than the wind blowing from the face of this wing?
A new family of wing profiles with slot .. NACA FELIKS
Andrew
post #380 of 449 (permalink) Old 12-23-2013, 05:16 AM Thread Starter
Christmas gifts:
here my scan such a disease illustrate how will they move the pistons in my engine in 1981, there was no possibilities of making animation and we had to somehow manage .. and the adoption of a decision which is to be the angle of the upper shaft between the pistons was not easy .. But it turned out, however, the simplest of which is 90 degrees should fulfill its task and so happened .. Exactly the drawing start is: 0 degrees angle of the suction piston, the piston 90 degrees exhaust (the figure is badly) and the main piston 80 degrees ..
Here how the work ..
Marry Christmas
Andrew
Closed Thread
    To stroke or not to stroke? basix W201 190-Class 3 12-04-2007 01:47 AM
    BABY HAD A STROKE TODAY !!!!!! Smokiesman W124 E,CE,D,TD Class 9 10-28-2004 08:49 AM
    A Stroke Of Luck Terabyte W123 E,CE,D,CD,TD,TE Class 4 08-04-2004 10:19 PM
    Engine Stroke Kit pcm0928 W202 C-Class 1 07-24-2003 09:00 PM
    Bore & Stroke pcm0928 W202 C-Class 0 09-14-2002 08:13 AM
