New 4 stroke engine - Page 31 - Mercedes-Benz Forum
post #301 of 449 (permalink) Old 12-16-2012, 03:45 PM Thread Starter
Feliks Andrew's Avatar
Date registered: Dec 2006
Vehicle: Mercedes 508 D
How can I bypass the statutory 20 mm in diameter ... and we have a little more air in the engine intake manifold
Washington State University - Formula SAE
And here, if the exhaust pipe wrap neodymium magnets .... I have a small MHD...
Andrew
Feliks Andrew is offline
post #302 of 449 (permalink) Old 12-30-2012, 08:45 AM Thread Starter
Some experience with Palasma. In the film, the plasma is formed, even when the current is flowing in the nano-amperes...
And here is video showing that you can do in addition to current, lovely music, which instead of ordinary hum, will be extracted out muffler...
Plasma Speaker 2 - YouTube
Even serious business, what comes out of mufler treat seriously"
" Designing any exhaust system today is a challenge – especially when it is for an iconic sports car with a famous sound signature. Ricardo’s WAVE software was used by Porsche engineers in the development of the latest 911 model"
Regards Andrew and sends best wishes for New Year.
My private hand made plasma for cut 100 A
Cutting Torch :
http://www.google.pl/url?sa=t&rct=j&...55534169,d.d2k
post #303 of 449 (permalink) Old 01-07-2013, 03:36 PM Thread Starter
Another way of getting electricity from hot exhaust pipes. Termionic generator, such as the electron tube. Current density obtained is about 10 watts of 1 cm square area of ??the outlet pipe
http://fti.neep.wisc.edu/neep602/SPRING00/lecture9.pdf
Of course, the acquisition of the MHD generator, which has electrodes inside..
To assist the electron reactions, a high voltage can be applied, as in TIG welding machines,..
Andrew
post #304 of 449 (permalink) Old 01-07-2013, 03:37 PM Thread Starter
But nothing to prevent the high temperature of the inner cathode acquired using shale gas, or coal.
if we pipe with a radius of 10 cm heated, it will receive its length 1cm, 600 watts, which is enough for the house to its length of 20 cm or 12 KW .... ....
Extremely small heating stove diameter 20 x 20 cm, and everything we have in the house for electricity, including heating ..
In this case, the inner tube should have fins to really depriving heat of combustion.
Andrew
post #305 of 449 (permalink) Old 02-09-2013, 03:52 AM Thread Starter
Here, such a concept of the new engine to the bicycle. Will definitely help in fast biking, be using any fuel ... I wonder how, in practice, this will help ... This will definitely help ... can at all do not have to pedal?
Venturis
A Gyro Instrument System? (Your Options)
Andrew
post #306 of 449 (permalink) Old 02-09-2013, 03:53 AM Thread Starter
And all it may seem laughable, were it not for the dimensions of the venturi nozzle, which can this piece of brass with a film about the rate gyro, spin up to 10 000 rpm at 40 km / h ...
Andrew : D
post #307 of 449 (permalink) Old 02-10-2013, 04:16 PM Thread Starter
Of course, I see that freed the next ideas of something we are very happy. Introduced only basis to be developed. Now I am going to have such a number, which encourages the implementation of this idea. Venturi nozzle is one in the figure is the front surface of 3.14 x 2.1 x 2.1 = 13, 8 cm sqare.
6 pieces battery has 6 x13, 8 = 83.0 sqare cm. that is, it is only the surface 8 x 10 cm ....
A man riding a bicycle is at least a surface of 50 x 50 cm = 2500 sqare cm. Theory can obscure the surface without loss, for which he will be hidden. So such sixpack can theoretically put 2500/83 = 30 pieces ... without magnification face of the rider. So these 180 pieces of brass drums ....
Andrew
post #308 of 449 (permalink) Old 03-09-2013, 08:46 AM Thread Starter
If on the brass cylinder with electric gyro cut the steps for air, we get a full hybrid-electric-air drive ...For sure the electric motor would be well-cooled, which contributes to the miniaturization ..
Andrew: D
post #309 of 449 (permalink) Old 03-09-2013, 08:47 AM Thread Starter
The end of such passive sports engine exhausts:
These old-style sausages only reach about 0.2 atmosphere vacuum. A new way of sucking exhaust ejector via a venturi is able to achieve 0.8 atmosphere vacuum. We can add it to the engine power of about 30% if the well will adjust camshaft....
As a result of additional air into the exhaust also added clarity will improve as a result of combustion gases....
Croll Reynolds - Process Vacuum | Air Pollution Control
The company has also achievements in the treatment of gases, both solid particles and NOx ..
For large trucks and marine engines, you can give the water cleaner exhaust. Then, no longer see the black smoke from the exhaust pipe truck. A vacuum is created and injected via a closed loop water will improve engine efficiency as a significant ..
Andrew : D
post #310 of 449 (permalink) Old 03-09-2013, 08:50 AM Thread Starter
You can apply again in California, the first ...
Or Euro 10 standard
http://www.croll.com/air_library/bro...tscrubbers.pdf
Library - Technical Bulletins
Andrew
Closed Thread
To stroke or not to stroke? basix W201 190-Class 3 12-04-2007 12:47 AM
BABY HAD A STROKE TODAY !!!!!! Smokiesman W124 E,CE,D,TD Class 9 10-28-2004 07:49 AM
A Stroke Of Luck Terabyte W123 E,CE,D,CD,TD,TE Class 4 08-04-2004 09:19 PM
Engine Stroke Kit pcm0928 W202 C-Class 1 07-24-2003 08:00 PM
Bore & Stroke pcm0928 W202 C-Class 0 09-14-2002 07:13 AM
