» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > General Mercedes-Benz
Old 06-06-2008, 03:27 AM   #21 (permalink)
Feliks Andrew's Avatar
Date registered: Dec 2006
Vehicle: Mercedes 508 D
On one of aerial forum, describing my horse power meter, it re-wrapped in discussion for transmit force for transmission in helicopters theme limitation , very often.
I read this forum and , I has been orientated , that transmission is critical element in helicopter most
Sometimes. at creation of new invention, inspiration takes place at I safety of user most important
There is so and this time.
Understand how as critical thing beginning, try to omit she completely.
My constructions for carrying half- rotary engine directly try to joint impeller of helicopter, with out any transmission. In order to get low turns properly, I must use engine about outsized jumping capacity, and low rpm. My half -rotate engine, is accuracy, and size are reasonable.
Second ,safety important , are diesel fuel in this low rpm engine. Summary I increase safety twice.
It try to make similar to main parameters " " Chinook”.
Principle of operation half-rotate engine
Air cooling " piston"
And neither one cogged circle
I find same gear box at propeller C-130 Hercules airplane.
With torque sensor.
My work:
And again neither one cogged circle
Andrew
Feliks Andrew is offline   Reply With Quote
Old 06-06-2008, 03:37 AM   #22 (permalink)
With "cylinder" and popped...
Mutations "Long Cylinder" and 8 valve in one "cylinder"
Vwork ~~= 0,5 V , V=Scircle x long
Regards Andrew
Old 06-06-2008, 04:57 PM   #23 (permalink)
1995BlkS320's Avatar
Date registered: Apr 2007
Reliability issues on this project. will not go past 5000 miles with out major overhaul.
stay away but technology will catch up in time.
Mercedes Benz S320
S600 Wood Steering Wheel & GRILL
www.TheRealEstatePortfolio.com
1995BlkS320 is offline   Reply With Quote
Old 06-14-2008, 04:24 AM   #24 (permalink)
Are You know engine named Twin Feliks ?
Regards Andrew
Old 07-18-2008, 12:49 AM   #25 (permalink)
Largest in the World project engine .
This name: MULTIBOXER - its radial engine in horizontal position.
Tis is first cross head radial engine.
If made please using components Wartsila-Sulzer RTA96-C piston, cross head ,rod:
Engine 14 cylinders have 108,920 hp at 102 rpm .
My project engine have 45 cylinders end power ~~ 350. 000 hp
Tis is better ,so nuclear reactor in aircraft carrier ship.
Last time I do not like something very cogged transmissions too.
My horizontal engine need angle transmission.
Its my project crossheads 90 deg angle transmission:
Ma by twin crossheads angle replace old "differential" ??
Andrew
Old 07-30-2008, 03:47 AM   #26 (permalink)
Tis is first cross head radial engine.....
Andrew
New differential:
I don't like noise of differential too...
Andrew
Old 08-04-2008, 03:50 AM   #27 (permalink)
The Mathematical crossing short-circuit,
results of new easy differential :
...and add few viscous couplings
Andrew
Old 08-05-2008, 04:36 PM   #28 (permalink)
Next short-circuit:
Andrew
Old 08-08-2008, 03:13 AM   #29 (permalink)
And precise differential:
Regards Andrew
Old 08-12-2008, 04:18 PM   #30 (permalink)
Different new sites in animation Solid Works of new differential.
http://www.new4stroke.com/differ.wmv
Andrew
To stroke or not to stroke? basix W201 190E, D-Class 3 12-04-2007 12:47 AM
BABY HAD A STROKE TODAY !!!!!! smokiesman W124 E,CE,D,TD Class 9 10-28-2004 07:49 AM
A Stroke Of Luck Terabyte W123 E,CE,D,CD,TD,TE Class 4 08-04-2004 09:19 PM
Engine Stroke Kit pcm0928 W202 C-Class 1 07-24-2003 08:00 PM
Bore & Stroke pcm0928 W202 C-Class 0 09-14-2002 07:13 AM
