New 4 stroke engine - Page 24 - Mercedes-Benz Forum
post #231 of 449 (permalink) Old 07-15-2011, 10:13 AM Thread Starter
Feliks Andrew's Avatar
Date registered: Dec 2006
Vehicle: Mercedes 508 D
[quote name='gruntguru' post='5167127' date='Jul 12 2011, 06:36']With a dash of fantasy.[/quote]
Oh yes, a little bit of you have, then a little knowledge and work reliably over the idea and new invention ready.....
Here you can see perfectly that we can get plenty of potential energy generated by the aerodynamics, without any propellers....
It allows a range of up to 3000 km by glider...
Gliding - Wikipedia, the free encyclopedia
Andrew
Feliks Andrew is offline
post #232 of 449 (permalink) Old 07-18-2011, 03:40 AM Thread Starter
In other forum
Andrew:stir:
The main energies supplied to a glider is gravity and convection(solar) energy. Even a glider has to be able to change it's vector to operate at a gain. At the end of the day, a glider has produced very little work. If you were to try to power the world on the work performed levels of a glider, it would be a herculean task.[/QUOTE]
You know perfectly well, with new ideas about the rank of the fundamental, very difficult to penetrate to the use of mass...
But thanks to people like you, we can slowly try to..
Another, although not looking as Hekules, we have on video..
Instead, we can build an automatic flow of balls so that they can be sucked into the pipe.
A falling ball (or WATER) with wings, they can hit their way back after a shoulder wheel, similar to a water wheel, giving him his potential energy ..
Well, the automatic circuit, will cause the "Hercules" he can rest.
This is just an example of how we can use another way of generating energy this way.
Regards Andrew
post #233 of 449 (permalink) Old 07-19-2011, 02:29 AM Thread Starter
"The Water Wind Power Plant"
Love for "tuning" not gone...
Andrew
post #234 of 449 (permalink) Old 07-20-2011, 03:54 PM Thread Starter
post #235 of 449 (permalink) Old 07-25-2011, 02:14 AM Thread Starter
In other forum:
Originally Posted by Vicegrip View Post
Correct if you calulate based on single lift pulse per wing cycle. Bees get 2 lifts per wing cycle. People used to think the earth was flat and at the the center too.
Please to let us know how to make complex structures that are both strong enough to self suport and to resist 4000 years of storms? We simple people can see how a simple shape pile of rocks could last in an area that does not see sub 0C temps. Now all you need to do is figure out how to make electricity from a pile of rocks.
The pile of rocks:
Originally Posted by BlackTalon View Post
Hmmm, as someone with a structural engineering background, I see potential problems with that structure :lol:
Originally Posted by Lupin..the..3rd View Post
Needs more rocks.
No, I think it needs less air.
And I have hope that over the last 4,000 years we have learned, to build something more than just the pyramids and the pyramids.... :roll:
Andrew
post #236 of 449 (permalink) Old 07-25-2011, 02:16 AM Thread Starter
Well, with that lovely airfoil texture, I'm sure that that will start producing usable amounts of energy any time it's within the eyewall of a hurricane....
Also such a pile of stones, and a dangerous element of water, politely puts 2000 MW....
Andrew
post #237 of 449 (permalink) Old 07-25-2011, 02:17 AM Thread Starter
Not stones, Concrete with much steel and piping in it. Well under 100 years old and under constant care, maintenance and upgrades. Nothing polite about this project. Read up a bit and you will find it was made out of men and material. 0.0 % clever, 100% brute force and slide rule engineering.
Concrete is a pile of stones, only a tiny...
If we use the design of computers, calculators to calculate the type,
Venturi calculator
VisualFoil 5.0 | Easy-to-Use Airfoil Software
It can be 100% clean design
And even more politely 'll gain energy. And then it will be possible, for the next 4000 years.
Andrew
post #238 of 449 (permalink) Old 07-30-2011, 10:53 AM Thread Starter
post #239 of 449 (permalink) Old 08-01-2011, 09:57 AM Thread Starter
post #240 of 449 (permalink) Old 08-05-2011, 07:28 AM Thread Starter
Andrew
Closed Thread
To stroke or not to stroke? basix W201 190-Class 3 12-04-2007 12:47 AM
BABY HAD A STROKE TODAY !!!!!! Smokiesman W124 E,CE,D,TD Class 9 10-28-2004 07:49 AM
A Stroke Of Luck Terabyte W123 E,CE,D,CD,TD,TE Class 4 08-04-2004 09:19 PM
Engine Stroke Kit pcm0928 W202 C-Class 1 07-24-2003 08:00 PM
Bore & Stroke pcm0928 W202 C-Class 0 09-14-2002 07:13 AM
