Andrew,
That was some interesting work. I will show your links to some of my students during the spring semester starting in a couple of weeks. Stay on this forum so I can collect enough questions from the students for you to answer. I will be teaching an engineering senior design course and will bring up your design in class if you don't mind.
Prof. Drew
Certainly . It for proper development of construction fairest expensive < way >. Young students it for development staff these projects. Then, they will not be feared this new.
Regards Andrew
Regards Andrew
First design to research:
or steam version:
New steam engine (only one) using in Big Boy locomotive,ships, tractor, or enegy plant.
Possible fuel: biomass ,wood,peat, russet coal,coal,ethanol,biooils,oil,hydrogen,biogas,LPG, natural gas,uranium,fusion.
One complete/ coil magnet give Continuous Force 50 Lbs [222N] Linear stepper
50 pc cake - about 2500 Lbs [11100 N]
On picture are 56 cake. Sum 56 X 2500 =140 000 Lbs
70 000 KG [621600 N]. Speed 2 m/sec.
Ship, press, train, hybride.
Tongues in engines manner of measurement of amount of mechanical horse.
Each engine owns invariable parameters about definite , like :
Sum of inertia mass, sum inertia springs, chains ,valves,etc.
Each model of engine has this parameters exactly SAME !!
And if for example, we want it without load for 4000 RPM ,at same time , we need exactly SAME horsepower.
It is principle my idea: Horse Power Meter.
Manner of measurement Horse Power:
Car is stop !!
We have running engine in idle RPM.
We need only same impulse classic RPM meter
Next we push and press i electronic meter switch "measurement"
Next we must push throttle in FULL .
Engine go to eg 5000 RPM.
Electronic measurement TIME with special SOFT , how long engine going measurement period 3000 rpm to 4000 rpm . This TIME are equivalent horsepower of engine.
Little power -long time , normal power - short time
Idea in diagram:
Next diagram electronic of Horsepower Meter, can made little 8 -bit processor eg. AT2051. Small individual Soft for each model of engine:
Happy Easter
Andrew
