New 4 stroke engine - Page 19 - Mercedes-Benz Forum
post #181 of 449 (permalink) Old 09-17-2010, 05:56 AM Thread Starter
Feliks Andrew's Avatar
Date registered: Dec 2006
Vehicle: Mercedes 508 D
Next Dixieland :
In some tubes can be hidden anti-missile ..
Regards Andrew
Feliks Andrew is offline
post #182 of 449 (permalink) Old 09-20-2010, 02:19 AM Thread Starter
To those dixielnds can efficiently drive Hydraulic, it may have, no peaks of specialized software, use the links below.
Venturi Tube - Simulation
Venturi Tube Simulation
AL0966B LESSON 2
The lower pressure propeller spins quickly ....
And review of the fact that it's not worth double the turbine insert...
Regards Andrew
post #183 of 449 (permalink) Old 09-20-2010, 12:53 PM Thread Starter
Mistake..!!
Regards Andrew
post #184 of 449 (permalink) Old 09-27-2010, 02:08 AM Thread Starter
A new way of sailing through a balloon which has the wind, and transmits energy to the propeller using hydraulics
And sailing version of the Venturi jets:
Regards Andrew
post #185 of 449 (permalink) Old 10-10-2010, 03:35 PM Thread Starter
I simply will look as flat block. It can be cast as a single unit. It did not need the division on the block and head. Because the pistons can be put at the bottom......
It is full 4 stroke engine.
Regards Andrew
post #186 of 449 (permalink) Old 10-14-2010, 07:30 AM Thread Starter
A Long, Strange Trip Downwind Faster Than the Wind | Autopia | Wired.com
My version of car wind.Solo of trumpet
Will test whether it could be faster than the wind... Boat too....
ICE BOAT
Regards Andrew:
post #187 of 449 (permalink) Old 10-15-2010, 07:21 AM Thread Starter
But perhaps the experience of the Ice Race can to help you change the aerodynamics in F1?
But in F1, there are winds above 300 km / h !
Fighter aircraft F-104 starts at a similar velocity. Right then, about 700 KG per 1 square meter load.
If using a well-sculpted are did the 700 KG used to accelerate boild F1 ......
I think that not everything has been said in the aerodynamics of F1.....
700 KG at 1 m^2 - 70 KG forward at 10 dcm^2 aditional F1 wings....
Regards Andrew
post #188 of 449 (permalink) Old 10-15-2010, 08:12 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Poland: kielbasa and crack.
flyboyike is offline
post #189 of 449 (permalink) Old 10-17-2010, 03:12 PM Thread Starter
Can it save fuel by using the wings ??
It all depends on how clever way it uses the wing...
Ice Boat
Sailing_faster_than_the_wind
Or, the cyclist can get speed of 200 km / h?
And they like to ride in the peleton?
The Phisics of sailing
Regards Andrew
post #190 of 449 (permalink) Old 10-24-2010, 06:45 PM Thread Starter
This problem ereting towers
can be resolved with Jazz Big Band. Just half of the turbine rotates in one direction and half in another page.
I did this study in the Venturi nozzle turbine and the calculations have a rather surprising results. Back to front.
Regards Andrew
Closed Thread
    To stroke or not to stroke? basix W201 190-Class 3 12-04-2007 12:47 AM
    BABY HAD A STROKE TODAY !!!!!! Smokiesman W124 E,CE,D,TD Class 9 10-28-2004 07:49 AM
    A Stroke Of Luck Terabyte W123 E,CE,D,CD,TD,TE Class 4 08-04-2004 09:19 PM
    Engine Stroke Kit pcm0928 W202 C-Class 1 07-24-2003 08:00 PM
    Bore & Stroke pcm0928 W202 C-Class 0 09-14-2002 07:13 AM
