New 4 stroke engine - Page 16 - Mercedes-Benz Forum
post #151 of 449 (permalink) Old 12-30-2009, 03:27 PM Thread Starter
Feliks Andrew's Avatar
Date registered: Dec 2006
Vehicle: Mercedes 508 D
If valves don't need valve clearance , it is the most considerable problem desmodrom will disappear .
Perhaps therefore it is possible to come back to old good desmodrom
Happy New Year, for all Friends.
Regards Andrew
Feliks Andrew is offline
post #152 of 449 (permalink) Old 12-30-2009, 05:07 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Regards Andrew
Dear Feliks,
I love you!
flyboyike is offline
post #153 of 449 (permalink) Old 12-30-2009, 06:42 PM
Kajtek1's Avatar
Quoted: 1226 Post(s)
Originally Posted by flyboyike View Post
Dear Feliks,
I love you!
Finally it become clear what all your replies are about.
Happy New Year.
Kajtek1 is offline
post #154 of 449 (permalink) Old 01-03-2010, 03:03 AM Thread Starter
I see a few places where you can be put the foam.....
1% of the weight is almost the same as error weighting.
Regards Andrew
HAPPYEND
More lucky ,please
Andrew
And pilots emergency landing in watter prefer ( no fire , etc)
15 bottle of foam cost 80 $ and this Piper Twin Comanche save. Rent a good motorboat and go home ...
This Art weight ~~15 KG If pilot no big posture ....
post #155 of 449 (permalink) Old 05-25-2010, 03:23 PM Thread Starter
"Salt water extraction"
http://www.new4stroke.com/pompa.pdf
And sallt water Tank:
1 m^3 / sec if H = 100 m give ~~ 1 MW ( 1000 KW) electric energy
Regards Andrew
post #156 of 449 (permalink) Old 05-26-2010, 03:19 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 385 Post(s)
It is slightly misleading here Felix, to use a heading 'salt water extraction'. That suggests to me the process of 'desalination'.
What you are actually showing here is wave power used to pump seawater into an upper storage tank.
keyhole is offline
post #157 of 449 (permalink) Old 05-26-2010, 04:16 PM Thread Starter
Sometimes, despite my limited knowledge of English, I can hit very close to my intention to transfer, to what I think should be provided.
Especially I call this act "extraction 'I mean` because of the analogy to oil extraction. It may also be associated with "Desalination", but in total, each understands what's really going on.
Using my words Extraction, is exactly the impression of energy extraction from the formative ocean.New analogy in order to facilitate the understanding that it is a "energy extraction"
In fact, of course, the question is how sweet you described. But I am concerned also about it right away it was associated with the production of energy in this way
Andrew
post #158 of 449 (permalink) Old 05-27-2010, 10:36 PM
Kajtek1's Avatar
It is hard to understand for most, that different language is not only different words and different grammar, but also different logic.
My favorite example is seeing something on TV, what directly translated from Polish would be "seeing something IN TV"
What's the deal with close to 100 years old patent? Andrew?
Kajtek1 is offline
post #159 of 449 (permalink) Old 05-30-2010, 07:36 AM Thread Starter
Originally Posted by DIAF View Post
Feliks,
Thanks for starting your thread again.
Please come up with a way to stop the oil gusher in the Gulf of Mexico.
Sincerely,
All of us.
I present my visions to resolve this difficult problem of stopping the oil slick:
You must first prepare a specially made item to seal the leak. It must have a large size that is 60 feet tall and 60 feet in diameter at its widest point. at the bottom of this item, please place a special knife around the bottom edge. Knife must of course be made of very hard material, such that will be able to cut all the metal parts that will be on its way
In his way will certainly be a lot of old items damaged hole.
Of course, that this knife can cut through all the elements needed to operate a very large force.
And here once it wisely:
So, yes, prepared some of the new valves (of course, completely open for the moment) should leave the head in the fire, so was in the middle of that item, the item with the valves can say, weighing about 100 tons. This does not allow the weight placed on its bottom remains the old structure with a knife.
But this element has a conical tank shown in the figure, which is thrown from the vessel through a pipe can fill it with concrete or specific, or a ball of iron. Its dimensions are 60 feet in diameter and 30 height. The size of this "cone" will be about 3,000 cubic meters (m ^ 3).
If you will fill it, for example, iron is its weight increased to approximately 21,000 tonnes. feel that this burden is not cheap, it was a knife to cut all the metal parts that are on the road. Ellement pockets certainly say that the bottom about 20 feet. It will seal.
The next step will be to close the new valve at the top of the item. Later, these valves will work even with the new pipe attached.
I think that despite the high oil pressure is also created so much of the burden will be able to seal the damaged head.
I totally do not know to whom to send my solution. So please read his message, where there is a chance that will go into the right hands.
Maybe it will help you seal the leak.
Regards Andrew Feliks
post #160 of 449 (permalink) Old 05-30-2010, 11:17 AM
flyboyike's Avatar
Quoted: 69 Post(s)
If prepositional differences were the only thing wrong with Feliks' stuff, it wouldn't be so bad. The problem is his posts are so far off the wall that I doubt if even he could make sense of them, had he not been the author.
Closed Thread
    To stroke or not to stroke? basix W201 190-Class 3 12-04-2007 12:47 AM
    BABY HAD A STROKE TODAY !!!!!! Smokiesman W124 E,CE,D,TD Class 9 10-28-2004 07:49 AM
    A Stroke Of Luck Terabyte W123 E,CE,D,CD,TD,TE Class 4 08-04-2004 09:19 PM
    Engine Stroke Kit pcm0928 W202 C-Class 1 07-24-2003 08:00 PM
    Bore & Stroke pcm0928 W202 C-Class 0 09-14-2002 07:13 AM
