New 4 stroke engine - Page 13 - Mercedes-Benz Forum
post #121 of 449 (permalink) Old 09-18-2009, 09:19 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Originally Posted by Feliks Andrew View Post
Are you sure??
Ulysse Nardin Chairman hybrid smart phone - Home
http://www.uncells.com/]
Regards Andrew
Quite sure, Feliks.
flyboyike is offline
post #122 of 449 (permalink) Old 09-19-2009, 01:22 PM Thread Starter
Feliks Andrew's Avatar
Date registered: Dec 2006
Vehicle: Mercedes 508 D
Originally Posted by flyboyike View Post
Quite sure, Feliks.
Still I don't believe you
And mutation pendulum dynamo:
Or magnet tooth plate.
So far we exploited the energy arising with the help of the pendulum only for stopping him.
Clik on picture, see animation
Wahad?o Waltenhofena
Regards Andrew
Feliks Andrew is offline
post #123 of 449 (permalink) Old 09-21-2009, 06:36 PM Thread Starter
It is a next mutation of the swaying pendulum around it pivot :
And it is a conception of containing inside box a dozen or so of such pendulums giving the electricity under the influence of moving. Of course completely hermetically sealed box.
It is next my proposal to use sea waves for the production of the electric current
Regards Andrew
post #124 of 449 (permalink) Old 09-22-2009, 05:50 PM Thread Starter
Now all tubules in one time are giving the energy from the move of the pendulum
And on the other side pendulums a next PCB set can also be. Altogether it for example 1000 pieces of coils and magnets of sets can be. Every coils is giving 1 watt.
Regards Andrew
Good alternate on flywheel ? ( turning the principle away perhaps of theses to be starter ( Large stepper motor))
Linear stepper
Stepper basic
post #125 of 449 (permalink) Old 10-01-2009, 12:50 PM Thread Starter
Now all tubules in one time are giving the energy from the move of the pendulum..........
Now I will show and I will explain the rule of operation my new dynastarter :
Next on hard PCB put some coils end electronics.
Every so the "green cylinder" has the magnet, two coils with shuffled teeth for the half of their size of the division, a bit electronics of the type small bridge on mossfets, securities on varistors electronics controlling generate the electricity . Current on each coil about 5 Ampers menage mossfets.
Everything controled of course with microprocessor .
It is put on this hard PCB plate about 150 of such arrangements with coils and the electronics parts
everyone so complet of elements is decreeing with 5 amperes, rally if to do about 150 pieces of these elements and to put them on this PCB tile, we can manage about 750 amperes what should completely be enough for the warming up the engine. Receiving the electric current in the same way for charging a battery is already a banally simple matter.
I think, that such PCB it "Automotive mother board" the same "Automotive mother board" is replacing the alternator and the starter. Flywheel still is always in the engine.
Principe as same , but in disc version linear stepper
Regards Andrew
post #126 of 449 (permalink) Old 10-04-2009, 01:00 PM Thread Starter
Pcb are possible in 2 half part.
Two ribbon cable, and sensitive electronics put outside of hot engine.
On PCB only magnets and coils , and nonsensitive electronics filled with resin.
Andrew
post #127 of 449 (permalink) Old 10-05-2009, 04:20 PM
flyboyike's Avatar
Quoted: 69 Post(s)
Feliks, really, get either a job or a life or both.
post #128 of 449 (permalink) Old 10-10-2009, 08:34 PM Thread Starter
So far I didn't still deal with a brake system of the car .
Without any interference in a brake system existing so far, I will prolong his work live at least twice .
So so:
Do you know electric retarder in big truck and buses?
When they applied the ones electric retarder in these cars, consuming the part of a brake system it diminished repeatedly .
Rght now are possible using this retarder in little passengers cars
That is, when this my new idea ,will be applied dynastarter, one should also equip him with the function electric retarder. Namely, with the help of a brake pedal, at first to give the electricity on the one dynastarter with a view to braking for them, and only then, when braking will be this way insufficient, a brake pedal will start a traditional brake system .
This dismisser which will be possible for the accomplishment on dynastarter, will be acting on a bit of an other principle than electric retarderin lorries. That is, provided electricity to dynastarter, will be producing the braking torque similar to the holding torque in stepping motors.
I think, around when drivers will have the big red diode in the car ,led which will be becoming when traditional brakes are starting acting, they will be supposed this way to suppress ambitions so that she doesn't become , that is a traditional brake system is out of work. I think that an entire brake system used this way will be enough on all life of the car, without any exchanges of him parts friction.
This asolutely new function of new dynastarter.
Regards Andrew
post #129 of 449 (permalink) Old 10-10-2009, 09:19 PM
Date registered: May 2009
Vehicle: '95 C280
Send a message via MSN to JimGoose
You need prototypes and working examples. All the AutoCAD animations and drawings look impressive, but I don't know what any of them mean really.
Lets see a Youtube video of your prototype engine at work inside a car. And patent everything, license it, profit.
crazy thread
JimGoose is offline
post #130 of 449 (permalink) Old 10-12-2009, 06:42 AM Thread Starter
crazy thread
Very much interested, where from you know that these things aren't given for patenting ????
Principe oscillating disc dynamo (pendulum)
Red Pin :
Regards Andrew
Closed Thread
    To stroke or not to stroke? basix W201 190-Class 3 12-04-2007 01:47 AM
    BABY HAD A STROKE TODAY !!!!!! Smokiesman W124 E,CE,D,TD Class 9 10-28-2004 08:49 AM
    A Stroke Of Luck Terabyte W123 E,CE,D,CD,TD,TE Class 4 08-04-2004 10:19 PM
    Engine Stroke Kit pcm0928 W202 C-Class 1 07-24-2003 09:00 PM
    Bore & Stroke pcm0928 W202 C-Class 0 09-14-2002 08:13 AM
