New 4 stroke engine - Page 12 - Mercedes-Benz Forum
post #111 of 449 (permalink) Old 05-20-2009, 07:32 AM Thread Starter
Feliks Andrew's Avatar
Date registered: Dec 2006
Vehicle: Mercedes 508 D
Yes, at the animated film he doesn't have the outlet pipe and intake. In every traditional engine such pipes are and it is about dimensions very much determined which they have very much a large impact to ultimate parameters of engines. In this structure of the phenomenon occurring wtych pipes are much more intense than in traditional engines, because of opening and shutting a ports are during max speeds of pistons. At such violent opening, phenomena resonase are very strong. One should in detail work them out.. I applied such phenomena in my engine, having some given from one man worked Peenemunde under Werner Von Braun
http://en.wikipedia.org/wiki/Walter_Kaaden
Kadenacky was a forerunner .
http://en.wikipedia.org/wiki/Expansion_chamber
http://en.wikipedia.org/wiki/Kadenacy_effect
I designed at first time my prototype of engine 600 cm^ 3, to parameters 100 HP. And there is only a wonderful trick here: the Engine surprised me favourably, and has 2,5 times of more power than I established .... Neat trick !!!
In 1981 we dont have internet....
Some work with "resonace"
Eexhauts with cone:
exhauts with cone and mufler:
Regards Andrew
Ps. Catalic muffler no need... NOx practicaly aborted....
Feliks Andrew is offline
post #112 of 449 (permalink) Old 05-27-2009, 06:18 PM Thread Starter
Ok,
And now about the most important advantage of my engine
This structure how, higher I demonstrated the graph, has the different degree of compress ratio on placing angles between two crankshafts .
The changeable compression ratio was applied in a few advanced different structures of special engines .
He has most often been carried out with the help special Biceri pistons.
and these are virtues from using it
Thorough description in the NASA contango :
http://ntrs.nasa.gov/archive/nasa/ca...1980011788.pdf
In my structure exceptionally it is easy to carry out such a changeable compression ratio. He is carrying out sie it behind the help very of straightforward device for the picture. And most important: this device is changing the compression ratio in all top hats of the given engine(even for example 16 cylinders).
It is very much cheap way, and simultaneous in the reliable way is carrying out all described higher virtues of the changeable compression ratio.
Engine new 4 stroke has changeable compressio ratio.
It's up to the angle of coupling with the main piston .
Graph some varations:
Regards Andrew
post #113 of 449 (permalink) Old 08-10-2009, 04:22 AM Thread Starter
Higher I described a few fasts way to the autoload of the mobile phone behind the help of the watch mechanism to alone of winding, which driving the electric generator will load the phone call automatically at moves of the phone.
Now I am still presenting one way of solving such a mechanism.
At putting in the mobile phone let us say six of such mechanisms, it should be enough to holding the phone in the readiness to work and the stand-by.
But for all certainty that we will always be they could use the phone, even when long he was in the stillness he proposes to add the handmade knob for winding such a mobile phone up, similarly he is like it in watches with such a mechanism. Then we will already always be sure that we will be able to use our phone, because of it we will wind lichen by hand, and then really we will get the full independence from the electric current and the traditional battery charger.
At the amount of mobile phones 1000 000 000 which everyone is downloading from let's say 1 Watt, we will save it of current in the height of 1000 MW.
Regards Andrew
Particularly how you will go to the long fell-walking and you will get lost
post #114 of 449 (permalink) Old 08-10-2009, 02:40 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Feliks, get a life.
flyboyike is offline
post #115 of 449 (permalink) Old 08-11-2009, 05:17 AM
Date registered: Jun 2008
somebody should just ban this flyboyike thing, where are moderators when you need them?
mescaline is offline
post #116 of 449 (permalink) Old 09-14-2009, 03:17 PM Thread Starter
Weight piston and valve same diameter - 62 mm
Right now without springs. Only retainers.
Regards Andrew
post #117 of 449 (permalink) Old 09-16-2009, 02:33 AM Thread Starter
So that you get rid of the doubt next photographs with accurate data :
Diameter popped 75 mm , diameter piston 76.5 mm
Right now are you shure ?? Any washes.
Weight popped 75 mm 1000 G
weight piston & rod 76.5 mm 850 G
weight popped 62 mm 400 G
weight piston & rod 62 mm 370 G
But the window of the flight of the valve of 75 mm is only 64 mm, what is very similar to the window of the flight piston 62 mm .
That is it results from it that the valve of 75 mm is giving the same flight as the piston 62 mm that is 1000 G to 370 G !!!!!
==~~ 2.5 more weight popped to piston& rod !!
It only looks impossibly. but this way is.
In principle ,for them greater popped/piston diameter, it is this difference in weight will be to the benefit of pistons.
Regards Andrew
post #118 of 449 (permalink) Old 09-16-2009, 02:35 AM Thread Starter
Since when the keg came into existence, for it is her shipping by ships constituted a spot of bother. That is how, they forgot to attach, while swinging the ship rolled from one side to other side, hitting in not around with great energy. There was this great danger for the crew. That is how, they forgot to attach, while swinging the ship rolled from one side to other side, hitting in not around with great energy. I decided to use this energy for the production of the electric current with the help of the oscillatory dynamo. It is a pendulum driving the oscillatory dynamo around so with keg. It will be sufficient to install shipboard or for other swimming raft, and during waving we have the electricity, rather than danger
block of osillating dynamo:
Regards Andrew
post #119 of 449 (permalink) Old 09-16-2009, 11:22 AM
flyboyike's Avatar
Quoted: 69 Post(s)
Some good reading on Feliks' condition.
Delusional Disorder: eMedicine Psychiatry
post #120 of 449 (permalink) Old 09-16-2009, 12:43 PM Thread Starter
Are you sure??
Ulysse Nardin Chairman hybrid smart phone - Home
http://www.uncells.com/]
Regards Andrew
Closed Thread
To stroke or not to stroke? basix W201 190-Class 3 12-04-2007 12:47 AM
BABY HAD A STROKE TODAY !!!!!! Smokiesman W124 E,CE,D,TD Class 9 10-28-2004 07:49 AM
A Stroke Of Luck Terabyte W123 E,CE,D,CD,TD,TE Class 4 08-04-2004 09:19 PM
Engine Stroke Kit pcm0928 W202 C-Class 1 07-24-2003 08:00 PM
Bore & Stroke pcm0928 W202 C-Class 0 09-14-2002 07:13 AM
