99 E320 jerks - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 12-18-2006, 10:50 AM Thread Starter
Date registered: Oct 2006
99 E320 jerks
Hi,
My 99 E320 kind of jerks forward or seems to not have enough gas at lower gear when I start driving in the morning and gear shift seems not correct. I do warm the car up for about 3-4mins before driving. After I drive for sometime when I slow down or stop at traffic light, I dont see this problem. What could be causing this? Bad Oxygen senor? Or is it the transmission going bad and not shifting correctly?
I am not too worried about the other problems but worried about transi going bad. What are the typical symptoms of transmission going bad?
Thanks much in advance.
dirtyharyus is offline
post #2 of 4 (permalink) Old 12-18-2006, 11:02 AM
Date registered: Nov 2006
Vehicle: 88 420 SEL, 99 CLK 320 Cab-SOLD
the first thing I would do is have the tranny fluid level checked after driving it around for a while, how many miles since the tranny fluid was changed? Also is the check engine light on-any codes?
Palm Tree Mechanic is offline
post #3 of 4 (permalink) Old 12-18-2006, 11:08 AM
Misfit's Avatar
Date registered: Nov 2005
Vehicle: '09 B200, '05 Smart
Not sure if it is valid on an MB - but my old infiniti had that same issue when the cylinder coils went .....
Misfit is offline
post #4 of 4 (permalink) Old 12-18-2006, 01:44 PM Thread Starter
Thanks palm tree and Misfit.
No check engine light on.
I had to change the conductor plate a month back as it was giving erroneous readings to the trany and and at that time new fluid was put in.
This car has 57k miles in it.
    ML500 creeps / jerks forward jwchi W164 M-Class 5 09-27-2006 06:29 PM
    car jerks at high rev. robinp R129 SL-Class 5 12-20-2005 07:49 AM
    2004 C32 Jerks boffer W203 C32 AMG, C55 AMG 4 12-14-2005 07:15 PM
    Update: Transmission Jerks 3-Star W164 M-Class 5 07-10-2005 11:48 AM
    Problem??? car jerks when I floor it???? help? s0vietbenz W140 S-Class 24 08-13-2004 12:24 PM
