15 inch rims on a 2002 c230coupe? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-15-2006, 09:08 PM Thread Starter
Date registered: Dec 2006
I've got a 2002 c230 kompressor coupe with the "raspy" 2.3, and would like to make it more roadworthy on tougher roads (drive to Mexico?) so would like to set up a bit like a rallye car, perhaps get it up a bit higher, but most importantly would like to use a smaller rim and taller (beefier) tire. Can I run a 15" from an earlier car? The car came with a 16" standard and 17 as option. Any info or suggestions appreciated
kompcoupe/euro107 is offline
post #2 of 3 (permalink) Old 12-17-2006, 10:39 PM
Date registered: Nov 2006
Vehicle: 1976 300d @460k
i dont know the exact offset for your c230 so i cant recommend an exact rim/tire combo but as long as you maintain your outer diameter it should be fine. for example if you had a set of 205/55 R 16's as long as you maintain the 205 dimension all of your ratios would be identical you would just "minus size" leaving you with a smaller rim and a larger aspect ratio. go with a high end tire and you will be much better off and then the 40 dollar special. the construction quality is really apparent.
you could take a page from R/Ver's who carry two full size spares just incase. if you mounted everything on steel rims you would not only have a strong and inexpensive set up but you would also have a full set of curb rash ready winter rims
understand you will not get the same handling as you will have taller and therefore less ridged sidewalls. this would minor but apparent in everyday touring.
otm646 is offline
post #3 of 3 (permalink) Old 12-18-2006, 02:57 AM
n5160u's Avatar
Date registered: Apr 2004
Vehicle: 2000 Designo SLK-05 C230WK-05 E320CDi-2010 GLK 350
Check the size of the rim your spare tire is mounted on and the sticker showing approved tire sizes which is usually found on the "B" pillar or inside the fuel filler door. If it is a 16, the brake rotors and calipers may be too large to fit within a 15 inch rim.
Potato Chip, custom canuter valve, low-friction muffler bearings, synthetic turn signal fluid, Hi-Definition Progressive Scan Wiper Blades.
Law-makers are supposed to regulate in the interest of the public as opposed to regulating in the interest of the regulated party.
If it says Pratt and Whitney on the outside it better say Martin Baker on the inside.
n5160u is offline
    FS: 20 inch rims & Focal 13 inch subwoofer da_fantasie For Sale/Wanted/Trade/Giveaway 5 04-22-2014 11:01 AM
    FS: 20 Inch Brabus Rims and 13 Inch Focal Polyglass Subwoofer da_fantasie W163 M-Class 9 03-10-2007 02:06 PM
    FS: 20 Inch Brabus Rims and 13 Inch Focal Subwoofer da_fantasie For Sale/Wanted/Trade/Giveaway 1 12-11-2006 02:23 AM
    FS: 20 inch rims and Focal 13 inch subwoofer da_fantasie W163 M-Class 2 09-20-2006 11:45 PM
    For Sale: 2002 Lexus LS 430 16 inch tires and Brand new 2002 LS430 16 inch Chrome wheels Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 02-20-2002 07:24 PM
