Mercedes benz E300TD Turbo Diesel wagon 1987 - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 12-15-2006, 12:26 AM Thread Starter
Date registered: Dec 2006
have this 1987 or 1986 E300TD turbo diesel wagon the bin No. is WDBEB93DXHF035977. Had this car almost 10 years now and only this year a few months back i had a problem when i apply a brake.
when i apply a brake when i am nearing a hump, and my speed is almost at a stop, the pedal hardens or push back, so i have to let go and push the pedal back again to still reduce speed. I noticed the brakes on the right front wheel is the one that engaged earlier than other tires cuz as if it leads the car to right.
had it analyzed, the mechanic said it might be along the ABS sensors that might have a defect. so through process of elimination we disconnect the cable above the engine which leads to the ABS harness along the front tires and the problem was solved. i did not encounter those problems anymore, but quite annoying because you can see the light light up in the instrument cluster under ABS.
So i didnt want that i want it to function, so they recommended to clean the "gear like portion" what you may call it? where the ABS sensors are located behind the front wheels, because they say if it is covered with dirts or anything that will also make the ABS sensor malfunction.
After cleaning it, we connected the cable again which connects the harness of the ABS sensor and it was running well again, but not for long only weeks then back again. (But i noticed this time when i encounter this pedal hardenning on an almost stop speed, it doesnt go to the right anymore, maybe they were engaging at the front wheel at the same time?)
They say i have to change the ABS sensors itself. But i was hesitant because if the sensors itself is damaged the ABS light should light up and if damage how come sometimes it works and sometimes not. If damaged then it should not work permanetly right? i wanted to inquire first before accepting his verdict, cuz this quite an expensive part and i have the left and the right to change if that was true.
I know the Mercedes Benz make good quality parts and does not get damaged in a few years time especially parts as delicate as this where you hang your life on the road?
can you help?
juralja is offline
TRADE 1984 300D turbo for 1982-1987 turbo wagon (300td) DieselKraut For Sale/Wanted/Trade/Giveaway 1 10-06-2015 11:50 AM
WTB: 1987 300 TD Diesel Wagon alaskagrown For Sale/Wanted/Trade/Giveaway 0 12-13-2005 08:29 PM
1989 Mercedes-benz 200TD Diesel Station wagon 124via126 W124 E,CE,D,TD Class 1 10-24-2005 08:01 AM
1987 2.5 Turbo Diesel on ebay...sort of bruce190td W201 190-Class 0 10-23-2004 08:38 PM
1991 Mercedes benz 300 Diesel Turbo Guest (MBNZ) W124 E,CE,D,TD Class 3 03-29-2002 08:24 PM
