What oil? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 12-14-2006, 04:55 PM Thread Starter
GPS
Date registered: Dec 2006
Vehicle: 99 E300DT
What oil?
I am a recent , first time Benz owner. Just purchased a 1999 E300 TD in showroom condition with 155,000 km. I have always serviced my own vehicles and will attempt to continue to do so. This car has always had Quaker State 5 W 30 European synthetic oil. Can't find it but did find Q. S. 5w30 Advanced synthetic. How critical is it to use the exact same oil? Or can I use any Brand name synthetic 5w30? Thanks in advance for any and all replies. Ont. Canada.
GPS is offline
post #2 of 4 (permalink) Old 12-14-2006, 05:01 PM
H-TownBenzoboy's Avatar
Date registered: May 2003
Vehicle: 81' 300SD, 82' 300D
Quoted: 2 Post(s)
Welcome to BenzWorld. If you can't find the Quaker State oil, find Mobil 1 5W-40 or Mobil 1 0W-40.
Here's a list of all of the MB approved oils.
http://www.whnet.com/4x4/oil.html
1981 300SD DB881 ext./code #236 leather int. aka: thistle green ext./olive int.
1982 300D, DB877 ext./code #135 mb-tex int. aka: petrol green ext./creme int.
H-TownBenzoboy is offline
post #3 of 4 (permalink) Old 12-18-2006, 12:08 AM
Date registered: Nov 2006
Vehicle: 1976 300d @460k
with so few miles the motor is a relative baby. most the oils sold have a similar addditives package save for mobile 1,and most come from the same base stocks from the same supplier. i would also be certan to use a highquality glass fiber filter if your not using an oem part.
otm646 is offline
post #4 of 4 (permalink) Old 12-18-2006, 12:31 AM
Vehicle: 83 300SD(w126), 87 300D (W124)
that quaker might not be diesel rated as its a 5w30 but i might be wrong.
Mobil 1 0w40 is whats recommneded for the OM606 turbo in your E300 diesel but the 5w40 wont hurt it either and it has better diesel ratings.
You can easily find 0w40 mobil 1 at walmart or kragen.
http://www.mobiloil.com/USA-English/...l_1_0W-40.aspx
OR another option would be shell rotella 5w40 synthetic which is also easily found at walmart.
MINE:
04 E55 AMG
previous:
81 300SD
92 190E 2.6
83 300SD
95 S500
96 S420
02 VW jetta TDI
78 300D
03 C32 AMG
02 C32 AMG
87 300D-AMG
85 190E 2.3
99 E55 AMG
greasy_benz is offline
    talking E300 oil filters ( We might be using the wrong oil filter for FSS use) bhowell_10 W210 E-Class 20 03-16-2012 08:22 AM
    Are these gaskets light or heavy wear? (Oil pan & oil filter) Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 9 08-24-2006 07:57 AM
    HOWTO: Replacing Cam Oil Line Fittings (Oil Guides) on the 119 (5.0L) V8 inetd W140 S-Class 3 12-02-2004 10:01 AM
    My 96 S320 to have a cracked engine block gasket, which cause a oil leak .All oil changes (more)... Guest (MBNZ) W140 S-Class 2 04-19-2002 02:34 PM
    oil exceeds max warning....i get this everytime i get an oil change with 8.5 qrts..is that too much. concerned C208/A208 CLK-Class 2 10-21-2001 06:56 PM
