e320 brake lamp - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 12-14-2006, 11:21 AM Thread Starter
Date registered: Dec 2006
Quoted: 2 Post(s)
e320 brake lamp
I've seen this issue posted before. The "bulb" warning came on in my '97 e320 sedan and I discovered that the back passenger brake lamp was not working.
I replaced the lamp and it worked for a short time before the warning came back on. I have heard that the contacts on the mount are responsible. Is there anyone who can recommend a quick fix to this problem?
tpush320 is offline
post #2 of 6 (permalink) Old 12-14-2006, 11:49 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 86 Post(s)
I don't have the same model as you do, but the slk's were having the same problem. Before the recall, several people tried a quick fix. You will have to do a search of the R170 forum. It may work for you.
Was there a recall on your brake lights by any chance?
Mike
Michael Pillay is offline
post #3 of 6 (permalink) Old 12-14-2006, 12:13 PM Thread Starter
Quoted: 2 Post(s)
No recall..and I've seen the problem posted before. The brake light works when I screw it in, and then will stop working intermittently.
tpush320 is offline
post #4 of 6 (permalink) Old 12-14-2006, 01:07 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hi, Tpush, welcome to the forum.
Head to the 210 forum, there is a DIY sticky for all sorts of things, that socket issue included. Whenever you have a specific issue about your model that's the best place to post.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #5 of 6 (permalink) Old 12-14-2006, 01:19 PM
Date registered: Oct 2006
Vehicle: 1998 E320
On my 1998, I had the same kind of problem. Turns out, the circuit had melted somewhere inside the the housing. The dealer replaced at no cost.
Texas is offline
post #6 of 6 (permalink) Old 12-14-2006, 04:17 PM Thread Starter
Quoted: 2 Post(s)
Thanks for the tip .. will head to the 210 forum.
tpush320 is offline
    My Rear brake lights and 3rd brake lamp stay on all the time! mclasser W163 M-Class 1 09-16-2006 04:17 PM
    Wagon 3rd brake lamp MBeige W123 E,CE,D,CD,TD,TE Class 5 01-11-2006 11:19 PM
    Lamp Defective light (brake lamp) BatBenz W210 E-Class 8 08-18-2005 03:23 PM
    02 C230 coupe brake lamp ahcoraj W203 C-Class 2 07-26-2005 06:40 PM
    Help with Replacing E320 Instrument Lamp rac43 W211 E-Class 2 12-16-2004 07:30 AM
