Engine check caution light - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 12-09-2006, 06:47 PM Thread Starter
Date registered: Nov 2006
CL light is black
HELP.
My engine check CL does not illuminate, when key is position 2.
Replaced a new bulb just in case and still no light, what next for trouble-shooting.
Should I remove battery power for a minute to reset something.
ML430
PUPU is offline
post #2 of 6 (permalink) Old 12-10-2006, 10:58 AM
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
Originally Posted by PUPU
CL light is black
HELP.
ML430
Not sure I understand your problem, but if you are talking about the CEL (Check Engine Light) it is supposed to be "black" unless there is something wrong w/ your car. Why on earth would you want it to come on???
Don't believe everything you think
Jayhawk is offline
post #3 of 6 (permalink) Old 12-10-2006, 11:59 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Aren't most warning lights on (at least for a short time) before you start the car, key in "ignition on" position? This allows the driver to be sure that the systems are operative. Have to say that I don't know if my car still does this, now that they have all sorts of "lamp failure" systems.
Could go and check but I don't have an ML anyway.
Diesel Benz is offline
post #4 of 6 (permalink) Old 12-10-2006, 01:06 PM
Jayhawk's Avatar
Good point! I know a lot of my warning lights flash when I start the car, and I would go check my CEL but I don't have an ML either...
Jayhawk is offline
post #5 of 6 (permalink) Old 12-10-2006, 01:09 PM
Jayhawk's Avatar
Oh hell, the Chiefs just took a time out so I went out and checked mine, and sure enough my CEL comes on w/ key in ignition 2 porsition.
Jayhawk is offline
post #6 of 6 (permalink) Old 12-10-2006, 02:08 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
If bulb is good, could be an ECU fault. Have dealer check.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
    Engine check light caution light PUPU W163 M-Class 9 12-04-2006 06:19 AM
    would blown dashboard light make check engine light go on? ae98 R170 SLK-Class 3 10-07-2006 01:36 AM
    check engine light & flashing fuel guage light pd99sl500 R129 SL-Class 7 02-27-2005 05:31 PM
    wierd engine behavior w/ check engine light, dealer unable to solve spovilaitis R170 SLK-Class 6 12-12-2003 09:05 PM
    Help Please!!! Check Engine Light...Empty Fuel Light Flashing mJstk01 R170 SLK-Class 6 05-18-2003 11:53 AM
