Mole Skin for Windows - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-07-2006, 06:19 AM Thread Starter
Date registered: Nov 2006
Vehicle: 2003 SLK 230
Hey all. I'm usually on the SLK board but I wanted to get an opinion from a broader spectrum of MB owners. I've been having a problem with my tint scratching. The tint man took my door apart and noticed the cabin-side top panel seal (rubber foam type) had a few burrs on it causing it to cut the new tint. One of our Benzworld members suggested I use this mole skin strip for the inside edge of the seal and showed me this site.
http://www.tintprotector.com
Has anyone else tried this stuff before? I've heard if you use an adhesive to glue felt to the inside edge that it will eventually come loose and rub glue on the window then cause the window's motor to burn up, yada yada yada. But this site claims that it never comes loose (what else would they claim...right). Keep in mind I live in Jax, Florida where it gets pretty hot, rainy, dewey, humid, etc. And also do you think there is some sort of a spray that I could use on this rubber foam piece that would create a slick surface (permanent). Like maybe a teflon coat. That way it would be like a plastic on plastic connection with the tint.
For the time being I'm probably going to order that piece that has burrs on it and hope a new one is more slick. The kit for this mole skin only costs about $30 US. What do you think?
Here's the SLK thread that I started for background info just in case you have no idea what I'm talking about.
http://www.benzworld.org/forums/r170...w-tinting.html
1998 Dodge Dakota 5.2L 4x4 - Spare Ride
2003 SLK 230 - Deceased
2006 Suzuki Boulevard C50T - Daily Beater
2007 VW Eos 2.0T - Hers
JaxSLK230 is offline
post #2 of 3 (permalink) Old 12-08-2006, 07:39 AM Thread Starter
Alrighty then. Guess everyone's just as clueless as I am. Thanks anyway. I guess I'll order the strips then tell everyone how they work after it's been used for a while.
post #3 of 3 (permalink) Old 12-08-2006, 05:48 PM
Date registered: Dec 2006
the moleskin is the way to go ...if you apply it correctly and it has a PS adhesive on it..if you dont apply it correctly or it is a weak adhesive it will make for a huge mess of your windows in the summer time....i can still help you out with the felt if you havent ordered the kit already...just give me a call at 904-880-4442
Eclipsetint is offline
    Cheerleaders not showing skin tiggerfink Off-Topic 7 04-17-2006 05:31 AM
    I Want This Ipod Skin! snips Off-Topic 8 04-02-2006 03:19 PM
    Things that make your skin crawl ThrillKill Off-Topic 41 03-29-2006 02:33 PM
    How can I avoid skin to break? Cixi R170 SLK-Class 3 01-12-2005 01:55 PM
    Sheep skin seat covers tiggerfink R230 SL-Class 8 07-20-2004 07:41 PM
