Weak washer pump - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 12-06-2006, 10:16 AM Thread Starter
Date registered: Dec 2006
Weak washer pump
Hello Benz nation
I'm new here as you can see and I heard many references to this forum. I figure let's try this sort of communication. Anyway I have 96 C220 and my washer pump has all of a sudden become weak to the point where the squirts are hardly reaching the windshield. Everything worked fine before I filled the washer tank full. That's maybe a coincidence. I never had anything but winter washer fluid in there and that will freeze at -40. Yes I am in Canada but it ain't that bad here. So any ideas on this? I suspect the pump is gone but maybe there is a trick or two that I don't know about. Thanks.
Babarogue is offline
post #2 of 4 (permalink) Old 12-06-2006, 10:41 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 737 Post(s)
Welcome to BenzWorld! The good new is that the pump is only about $16. If nothing is clogged/frozen, it seems a likely culprit.
GeeS is offline
post #3 of 4 (permalink) Old 12-06-2006, 12:07 PM Thread Starter
The quote I got from the dealer was $50.00. Where can I get one for $16.00?
Thanks
post #4 of 4 (permalink) Old 12-06-2006, 12:54 PM
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: 2002 CLK430
Thanks
Why, GermanStar dot net, where else?
MarcusF is offline
Windshield Washer Pump DIY? 97C28O W202 C-Class 1 08-22-2006 01:45 AM
Rear window washer pump (TE) myfirstbenz W124 E,CE,D,TD Class 2 01-10-2006 06:53 PM
washer pump kickboxer W126 S,SE,SEC,SEL,SD,SDL Class 2 12-08-2005 04:41 PM
Help for inoperative windshield washer pump herb R129 SL-Class 6 11-24-2005 09:35 AM
VDO washer pump upgrade Vato Wahuhi Vintage Mercedes-Benz 0 03-22-2005 09:02 AM
