GREEK Forum Members - Page 16 - Mercedes-Benz Forum
post #151 of 394 (permalink) Old 01-29-2007, 03:04 AM
GregoryGR's Avatar
Date registered: Aug 2006
Vehicle: 2006 Slk 200K
pgp737,
I tried hard, but unfortunately i didn t make it to join you at Megara... I really wanted to come...! Maybe our next meeting should include Megara...
Panos, do you have more photos?
A video?
Nice tyres!!!
How many cars were with you?
Post your time and also others'!
SLK 200K 6MT - Kleemann Powered
Athens
GregoryGR is offline
post #152 of 394 (permalink) Old 01-30-2007, 06:55 AM
pgp737's Avatar
Date registered: Dec 2006
Vehicle: SLK 200K 2005
We were a party of 3 cars, but in the track you could see many kavlotimonous (hot drivers) with small or biger cars, racing or street vercion.
My best lap was 1min 17sec with many mistakes.
The car is NOT for a track because it is to heavy at the front and has a little HP.
I had a lot of problems to turn in 140 deg. and more from the front understeer.
I am changing tyres and i will try again. I believe 1min 15sec is easy.
www.mbclub.gr
Hellenic Mercedes Benz Club
pgp737 is offline
post #153 of 394 (permalink) Old 01-31-2007, 05:50 AM
SiLK's Avatar
Date registered: Aug 2004
Vehicle: SLK350
A little quiet in here lately....!
Any particular reason?
What about that first Thessaloniki's meeting? Shall we try to arrange one for this or the next comming weekend? Any fans of this idea?
SiLK is offline
post #154 of 394 (permalink) Old 02-04-2007, 04:58 AM
Date registered: Jan 2007
ΠΡΟΒΛΗΜΑΤΑ Slk 171
Κατά την διάρκεια των 2 και κάτι χρόνων που είμαι κάτοχος της SLK (R171) έχουν παρουσιαστεί - σχετικά με την φήμη της Mercedes - πολλά προβλήματα.
Μερικά από αυτά καλύψανε με την πρώτη στην ΕΓΓΥΗΣΗ, άλλα μετά από προσωπική πίεση τα καλύψανε και τέλος, άλλα προβλήματα χρειάστηκε να τα πληρώσω...
Αναφέρω, αυτά που θυμάμαι... οπότε όσοι δεν έχετε ληγμένη εγγύηση, να τα ελέγξετε, για να προλάβετε χειρότερα και πιθανές οικονομικές επιβαρύνσεις μετά την λήξη της εγγύησης...
1. Πρόβλημα στο NAV... σβήνει μόνο του και επανέρχεται μετά απο 4-5 λεπτά. Το πρόβλημα εμφανίζεται συνήθως σε ακραίες θερμοκρασίες (πολύ κρύο ή ζέστη) και μετά απο πολύ οδήγηση. Μου αλλάξανε ολόκληρο το COMAND και η βλάβη συνεχίστηκε. Μου αλλάξανε κάτι από πίσω - στον χώρο των αποσκευών - νομίζω μια πλακέττα και το πρόβλημα φτιάχτηκε. ΔΕΝ ΠΛΗΡΩΣΑ, διότι ήταν μέσα στην ΕΓΓΥΗΣΗ
2. Διαρροή από την τάπα στο δοχείο με ΒΑΛΒΟΛΙΝΕΣ. Παρουσιάζει διαρροή. Μου την αλλάξανε 2 φορές, στο διάστημα 2 ετών. Το προβλημα το διαπίστωσα, από τις αναθυμιάσεις που προξενούσε η βαλβολίνη που έφευγε, πάνω στην εξάτμιση και από ένα μεγάλο λεκέ στο γκαράζ, στο ύψος της μηχανής. Το πρόβλημα ξαναεμφανίστηκε για 3 φορά και δεν μου το καλύψανε απο την εγγύηση !!! μετά παό πίεση, μου έκαναν έκπτωση 50%
3. Πρόβλημα στο αριστερό παραθυράκι. ΤΟ παράθυρο το μικρό το τριγωνικό, όταν κατεβαίνει για να ανοίξει η οροφή, αλλά και όταν ανεβαίνει, τρίζει πολύ. Την πρώτη φορά για να με ξεφορτωθούν, έβαλαν λίγο λιπαντικό για να μην τρίζει, μετά από λίγο το πρόβλημα συνέχισε και μου αντικατέστησαν τον μηχανισμό.... ΧΩΡΙΣ ΝΑ ΠΛΗΡΩΣΩ... Σήμερα, που έχει λήξει η εγγύηση, το τζαμάκι ξανατρίζει !!!! και δεν καλύπτεται από την εγγύηση...
4. Πρόβλημα στην εξάτμιση. Ο κορμός της εξάτμισης ξεκόλησε !!!! από τα καζανάκια, ακριβώς εκεί που γίνεται διπλός... Η αντίδραση της Mercedes ήταν άμεση, όχι στην αντικατάσταση όλης της εξάτμισης !!! αλλά στην κόλληση της παλίας !!!!! Μου είπαν ότι δεν καλύπτεται η αντικατάσταση, αλλά μόνο η κόλληση !!!!
5. Ενδειξη SRS στον πίνακα οργάνων. Αναβει αδικαιολόγητα ? Δεν το έχω καταλάβει. Το πήγα την πρώτη φορά κα το μηδένισαν -αν κατάλαβα καλά - μέσω του διαγνωστικου φορητού υπολογιστή. Την 2η φορά που παρουσιάστηκε, μου αλλάξανε κάτι στο τιμόνι ΔΩΡΕΑΝ στην ΕΓΓΥΗΣΗ... Την τρίτη φορά, το πλήρωσα, διότι μου είπαν ότι φταίει η καλωδίωση στο κάθισμα του συνοδηγού... και είχε λήξει η εγγύηση.
6. Προβλημα στο κλειδί / τηλεχειριστήριο. Θα πρέπει τέλος να ομολογήσω, ότι ορισμένα μικροπροβλήματα, όπως πχ το κλειδί που χάλασε, μου το καλύψανε μετά από 2 μήνες απο την λήξη της Εγγύησης, μετά απο έγκριση από το εξωτερικό και μετά από 15 μέρες αναμονή. Συγκεκριμένα είχε ραγίσει/σπάσει η μεβράνη στα κουμπία και δεν υπάκουε στις εντολές.
Τέλος, θα πρέπει να σημειώσω, ότι τα πιό πολλά προβλήματα τα γνωρίζουν στην Ελληνική Mercedes, αλλά κάνουν τις "πάπιες" όταν τους τα λές στα συνεργεία !!!! Προσπαθούν να κερδίσουν χρόνο, για να λήξει η εγγύηση και να μην στα καλύψουν . Γι' αυτό να είστε πολύ πιεστικοί.
Θα πρέπει να ξέρετε ότι όλες οι βλάβες καταγράφονται, σε παγκόσμιο επίπεδο σε κάποιο κεντρικό cοmputer, όπως και οι προτινόμενες λύσεις / επισκευές. Αυτό που θα θεωρούσα δίκαιο από μία εταιρεία σαν την Mercedes, θα ήταν οι τεχνικοί, σε κάθε service ρουτίνας του αυτοκινήτου, να εέγχουν από μόνοι τους τα "προβληματικά σημεία" για να μην βρίσκεται ο οδηγός / πελάτης μπροστά από προβλήματα.
Αυτά για την ώρα.... Στείλτε και εσείς τα αντίστοιχα προβλήματα που συναντάτε...
SLK - R171
pavlos2004 is offline
post #155 of 394 (permalink) Old 02-04-2007, 04:59 AM
COMAND APS - SLK Hidden Menu
Μπορείτε πολύ έυκολα να έχετε πρόσβαση στο Hidden Menu του COMAND APS !!! και να ρυθμίστε δύο πολύ χρήσιμες παραμέτρους...
Ο λόγος που γίνεται αναφορά, στα παρακάτω, είναι διότι ορισμένοι ΕΚΜΕΤΑΛΛΕΥΤΕΣ σε καταστήματα τοποθέτησης ραδιοκασσετοφώνων, προθυμοποιούνται να στα ρυθμίσουν, μετά από πληρωμή 100 και 150 ευρώ !!!!! Δουλεία 3 λεπτών, χωρίς προβλήματα και ιδιαίτερες γνώσεις....
ΠΡΟΣΟΧΗ !!! Δεν χρειάζεται να πληρώσετε ΤΙΠΟΤΑ !!!
Η πρώτη αφορά την δυνατότητα του DVD να πάιζει και "εν κινήσει". Απλά να ξέρετε, ότι θέλει προσοχή, αυτή η ρύθμιση, δι΄τι είανι επικύνδυνο για να σας αποσχολεί, όταν οδηγάτε, αλλά πολύ χρήσιμη για τον συνοδηγό.
Η δεύτερη ρύθμιση, σας δίνει την δυνατότητα να "μηδενίσετε" ή να αλλάξετε τον Κωδικό Περιοχής (Region Code) των DVD και να βλέπεται όλα τα DVD, όλων των Region Code ! Σ'εμενα που βλέπω / ακούω μουσικά DVD και καινούργιες ταινίες, μου έλυσε τα χέρια.
Υπάρχει αρχείο PDF, στο οποίο αναφέρονται όλα αυτά.
SLK - R171
post #156 of 394 (permalink) Old 02-04-2007, 05:08 AM
My SLK
Μπορείτε να δείτε και την δικιά μου SLK.
Μία από τις πρώτες SLK που κυκλοφόρησαν στην Ελληνική αγορά.
Εγινε ειδική παραγγελια, 4 μήνες πριν με full extra... μπήκαν σχεδόν όλα από τον επίσημο κατάλογο της Mercedes Benz.
Μπήκαν πολλά extra, όπως :
COMAND APS - NAVIGATION,
PARKTRONIC,
Ηχοσύστημα 11 ηχεία,
Χαμηλή sport ανάρτηση,
Aircraft και Θερμαινόμενα καθίσματα,
Κλιματισμός με ψηφιακές ενδείξεις,
Πίσω αεροτομή AMG,
Οriginal ανεμοθραύστης από plexiglass,
Ειδικός εσωτερικός φωτισμός,
Αισθητήρας βροχής και φωτός,
Δύο συναγερμοί εργοστασιακοί,
Αυτόματα αναδιπλούμενοι καθρέπτες,
Ανοιγμα οροφής με το control των κλειδιών απο απόσταση,
Σειριακό / αυτόματο κιβώτιο ταχυτήτων,
Διακοσμητικά στο καπώ (όπως η SL)
Αλλαγή ταχυτήτων από τα χειριστήρια στο τιμόνι,
Kοντή κεραία (όπως η SL)
Τηλεφωνική εγκατάσταση car kit για Ericsson,
Φώτα Bi-Xenon περιστρεφόμενα ανάλογα με την θέση του τιμονιού...
Εγιναν αλλαγές στα ζάντολάστιχα και στα φρένα μπροστά.
Εγινε αντικατάσταση των δίσκων με εργοστασιακούς 4πίστονους διάτρητους αεριζόμενους.
Τέλος, έγινε και επαναπρογραμματισμός του εγκεφάλου για αύξηση ιπποδύναμης.
ID:	115327   Click image for larger version
ID:	115328   Click image for larger version
ID:	115329   Click image for larger version
SLK - R171
post #157 of 394 (permalink) Old 02-04-2007, 05:12 AM
Αναβάθμιση ΦΡΕΝΑ / ΙΠΠΟΔΥΝΑΜΗ
Κατ'αρχήν η αναβάθμιση δεν προκαλεί κανένα πρόβλημα. Αλλωστε ο κατασκευαστής (MKB ή Brabus) προσφέρει και 2 χρόνια εγγύηση, για τα μηχανικά μέρη.
Η κατανάλωση ανεβαίνει ελαφρά στις μικτές διαδρομές (Πόλη - Εθνικη Οδός - Αττική οδός), χωρίς αυτό να γίνεται ενοχλητικό.
Η κατανάλωση ανεβαίνει στο ρελαντί... δηλ. αν σταματήσεις κάπου και περιμένεις να έρθει κάποιος, καλό θα είναι να σβήνεις την μηχανή σου.
Η μέση κατανάλωση κυμαίνεται από 10,5 litres - 12,5 litres/ 100 Km.... έχει γράψει και 7,8 litres / 100 Km στην Αττική Οδό.....
Αλλά μέσα στην πόλη με κίνηση, θα κυμαίνεται από 11,5 litres έως12,0 litres / 100 Km.
Από οικονομικής πλευράς, δεν έχει διαφορά διότι το α' στάδιο συμπληρώνει το δέυτερο.... Δεν πάει χαμένο.
Ξεκινάς από το πρώτο και μετά κάνεις το δεύτερο, πληρώνοντας μόνο την διαφορά.
Εμένα με εξυπηρέτησε συνεργάτης μέσα από την Mercedes και δεν έχω κανένα πρόβλημα.
Καλή δουλειά, ευγενέστατος και γρήγορος.
Τιμές δεν θυμάμαι, αλλά θα μάθω και θα σου πώ.
SLK - R171
post #158 of 394 (permalink) Old 02-04-2007, 05:16 AM
Slk : ΚΑΤΑΝΑΛΩΣΗ / ΕΜΒΕΛΕΙΑ / ΤΕΛΙΚΗ
Επισυνάπτω και 3 φωτογραφίες , που έβγαλα όταν αγόρασα την SLK μου, στην Αττική Οδό :
1. Κατανάλωση...
πολύ χαμηλή 6,5 liters / 100 km
με μέση ταχύτητα 90 km/h
2. Εμβέλεια...
πολύ μεγάλη 954 km
βάσει της παραπάνω κατανάλωσης
3. Τελική ταχύτητα...
αγγιξα τα 233 km/h
(με αυτόματο / σειριακό κιβώτιο ταχυτήτων)
ID:	115332   Click image for larger version
ID:	115333   Click image for larger version
SLK - R171
post #159 of 394 (permalink) Old 02-04-2007, 05:37 AM
ΑΞΙΖΕΙ ΝΑ ΤΟ ΔΕΙΤΕ - SLK AMG Special
Βρήκα κάτι φωτογραφίες απο μία Slk Amg και τρελλάθηκα !!!
Πολύ καλή δουλειά ! Μοναδικός εξοπλισμός.
Το σαλόνι καταπληκτικό.... και τα χειριστήρια στο τιμόνι, διαφορετικά απο αυτά που εξοπλίζεται το αυτοκίνητο...
Αξίζει να τις δείτε...
SLK - R171
post #160 of 394 (permalink) Old 02-04-2007, 11:52 PM
SiLK's Avatar
Vehicle: SLK350
Γειά σου Παύλε και καλωςήρθες στο Forum!
Πολύ όμορφη η SLK σου και πολύ καλές οι "παρεμβάσεις" σου! Κρίμα που σου έβγαλε αυτές τις βλάβες, Εύχομαι νά'ναι οι τελευταίες για σένα όπως και εύχομαι κανένας άλλος να μην μην ταλαιπωρηθεί από προβλήματα στο αμάξι του!
Όσο για την SLK55 AMG που αναφέρεις, αυτή είναι μια είδική έκδοση η οποία λέγεται "Black Series" και διαφέρει πολύ από τις 'κοινές' 55ΑMG.
Μερικές από τις σημαντικότερες διαφορές είναι:
  • Υποδύναμη 400PS και ροπή 520Nm (από τον ίδιο V8 των 5,5λίτρων)
  • Σταθερή οροφή (δεν γίνεται cabrio!)
  • Διαφορετικά καθίσματα και επένδυση από δέρμα, αλκαντάρα και carbonfibre στο σαλόνι
  • 19" ζάντες (8.5x19" με 235/35 εμπρός και 9,5χ19" με 265/30 πίσω)
  • και 45kg ελαφρύτερη (total 1495kg)
έτσι, το αποτέλeσμα, σύμφωνα με την Mercedes-Benz, είναι 0-100 σε 4,5sec (από 4.9) και τελική 280km/h (από 250)!
Τέλος, τα χειριστήρια στο τιμόνι (paddles), πλέον, νομίζω ότι αυτά βάζουν σε όλα τα μοντέλα (κατόπιν παραγγελίας βέβαια) αντί εκείνα τα τελέιως άβολα κουμπιά που είχαν στην αρχή!
SiLK is offline
    To the Canadian forum members.... C-Rod W163 M-Class 8 11-10-2006 01:04 PM
    Calling all D.C. forum members Endo-E W210 E50 AMG, E55 AMG 1 05-08-2006 10:25 AM
    Useful for some forum members..... firstmb Off-Topic 39 11-11-2005 10:02 PM
    Any members of MBCA on this forum? S-KLASSE8 Off-Topic 7 03-14-2005 07:36 PM
