Intermittant death - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 11-27-2006, 01:18 PM Thread Starter
Date registered: Nov 2006
Question Intermittant death
I have an 88 420 SEL that is cosmetically a 9.5 on a scale of 10. (140,000 miles) When it has been running for about 45 minutes it will die. After it sits, it will restart and behave. When it starts to act up, you can keep it running if are careful to barely give it any gas. When the car is running, it runs great. The hydrocarbons seem a bit high at idle, (canary-test).
I have done the following:
R & R and clean fuel tank
New pumps and filter
clean injectors
check fuel pressures
Check temp sensors
check TPS
replace O2 sensor
Replace ignition amplifier
replace fuel pump relay
Any direction is greatly appreciated. Richard Crump is offline
post #2 of 4 (permalink) Old 11-27-2006, 01:34 PM
Will Moderate For Cigars
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 200 Post(s)
I had a friend that had a W126 1991 300SE doing the same thing. It was the EHA valve but a temporary solution was to put the air conditioner selector switch on Economy.
You may want to post this in the W126 section for more input.
2005 S430 4Matic 'Morton' W220.183 • 722.671 Rest in Peace
Bells and whistles are thorns and thistles.
cmitch is offline
post #3 of 4 (permalink) Old 01-18-2007, 12:19 AM
Date registered: Sep 2006
Vehicle: 94 C220, 2001 C180
Have you tried the overload relay?
Timothys is offline
post #4 of 4 (permalink) Old 01-18-2007, 04:32 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 78 Post(s)
Instructions to test this relay are in the DIY sticky in the w126 forum.
Michael Pillay is offline
    Intermittant Wiper Budlyte R/C107 SL/SLC Class 9 02-06-2009 10:54 AM
    intermittant odometer DZL_Damon W123 E,CE,D,CD,TD,TE Class 5 10-20-2006 09:08 PM
    kickdown intermittant? zumwoll W123 E,CE,D,CD,TD,TE Class 1 09-19-2006 01:56 PM
    Intermittant Stalling kburns1969 W202 C-Class 14 08-16-2006 12:21 PM
    intermittant vibrating Guest (MBNZ) W124 E,CE,D,TD Class 6 02-17-2002 01:09 AM
