Battery completely dead! - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 11-27-2006, 11:54 AM Thread Starter
Date registered: Nov 2006
Cool Battery completely dead!
I have a 2003 E500 and have been having problems with the heated seats not working or working only when its warm outside? The rear heater seems to be always on (blowing hot air). I replaced the battery and now less than 30 days later the battery is completely dead. The car has 47K on it but is out of warranty. Does anyone have any suggestions as to a likely solution? Is there a 2nd battery in the car somewhere? ....plz help! I've thought MB was a reliable well engineered vehicle...after 8 months and four times in the shop I’m beginning to have doubts.
monty_62 is offline
post #2 of 13 (permalink) Old 11-27-2006, 12:24 PM
Kajtek1's Avatar
Quoted: 1163 Post(s)
Welcome to the forum.
I bet you bought the car quite cheap, because it has bad opinions?
Now you are complaining, that opinions are confirmed?
Coming to technical problems.
-there is only one battery in the car
-what "rear heater" you are referring to?
-did you let the car seat for 30 days and then notice the battery dead? That might be quite normal.
-if the battery gets drained in one day, get the ammeter, put it on battery connectors and start pulling the fuses to pinpoint the circuit with big draw. You'll always have minimal draw for radio and security system.
Kajtek1 is offline
post #3 of 13 (permalink) Old 11-27-2006, 01:06 PM Thread Starter
38K and the battery drained in one day. As for complaints...the car only has 47K on it and i've had it for 8 months. I never thought after buying a MB i would have to put an ammeter for problems in the first year...what's next pull the engine in my 2nd year?
monty_62 is offline
post #4 of 13 (permalink) Old 11-27-2006, 02:04 PM
ProV1x's Avatar
Date registered: Jul 2006
Quoted: 2 Post(s)
u bought a wrong car if reliability is what you're looking for. MB is rock bottom on CR ratings, and read any late model forums here, you'll see owners having TONS of problems.
there could be literally dozens of things that can cause battery drains, get it checked by a tech
Gone but not forgotten:
2003 Honda S2000
1999 BMW 540i sport
1995 BMW M3
ProV1x is offline
post #5 of 13 (permalink) Old 11-27-2006, 03:22 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
Let's not get emotional here, people, and instead let's try giving our friend some actual advice.
Monty,
Pull the fuse that's responsible for the seat heater. If after that the battery doesn't die again, there's your suspect circuit. Perhaps the heater relay (if equipped) is stuck on and is sucking down the battery. This is a fairly minor problem, no reason to dis the car over it.
flyboyike is offline
post #6 of 13 (permalink) Old 11-27-2006, 05:41 PM
Kajtek1's Avatar
Belive me, there is long way from sticky switch, or relay to engine replacement.
If you don't have an ammeter, you can take a higher-power light bulb and make a tester. If 20 W bulbs connected between battery terminal and car lights up with full power -you have big drain and that's the point you start pulling the fuses.
With normal draw the light bulb suppose to barely glow, or have no light at all.
In the past my friend bought a Volvo very cheap, because the battery was constantly dying. He enter the car at night couple days later and notice, that glove compartment light is on. Couple layers of electrical tape on the switch bumper solved the problem, that cost the seller thousands of dollars.
Kajtek1 is offline
post #7 of 13 (permalink) Old 11-27-2006, 11:13 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
You mean disconnect the battery cable and "measure" the idle current consumption? Normally a good idea but on an E500 2003 (is that a W210, W211 started 2003 in Europe) you get a service visit to clear ABS/ESP etc. if you disconnect the battery (did that once when the heater blower regulator failed and would have drained the battery any way during the night before it was fixed next day). A clamp ammeter would be better but those are costly for DC-current measurements. I guess one could try with an ordinary ammeter, connecting the meter first before disconnecting the battery cable, supplying power all the time. A bit difficult though to avoid any power loss.
Considering E-class quality, I believe W210 and W211 have a bit different issues. They have problems but the expectations are high too, I wouldn't say it is worse than the average and where they have problems, MB takes care of those quite well. This way the problems get more publicity, other manufacturers tend to get less publicity, it is not good for the owner if the car issue is not acknowledged neither fixed at no cost.
Edited: a mistake above, W211 started March 2002 in Europe.
Diesel Benz is offline
post #8 of 13 (permalink) Old 11-28-2006, 11:51 AM Thread Starter
fuse locations in 2003 E500
Does anyone know where I can get photos of fuse locations?
monty_62 is offline
post #9 of 13 (permalink) Old 11-28-2006, 12:06 PM
Kajtek1's Avatar
Originally Posted by Diesel Benz
You mean disconnect the battery cable and "measure" the idle current consumption? Normally a good idea but on an E500 2003 (is that a W210, W211 started 2003 in Europe) you get a service visit to clear ABS/ESP etc..
Since you already had your batter dead, than what exactly you worry about?
I've been disconnecting batteries on my Mercedes and the only worry was radio code.
If new models have electronic gizmos that needs reseting, you can connect ammeter before disconnecting the direct connection. This way you never disconnect the power from computer.
Kajtek1 is offline
post #10 of 13 (permalink) Old 11-28-2006, 12:35 PM
n5160u's Avatar
Date registered: Apr 2004
Vehicle: 2000 Designo SLK-05 C230WK-05 E320CDi-2010 GLK 350
W211 have two batteries. There is an aux battery to keep some of the electronics alive if the main battry in the trunk runs down or is disconnected. It is in the front. See the owners manual.
Potato Chip, custom canuter valve, low-friction muffler bearings, synthetic turn signal fluid, Hi-Definition Progressive Scan Wiper Blades.
Law-makers are supposed to regulate in the interest of the public as opposed to regulating in the interest of the regulated party.
If it says Pratt and Whitney on the outside it better say Martin Baker on the inside.
n5160u is offline
    Is 5month-old battery a garbage if completely drained???? ProV1x W210 E-Class 12 11-15-2006 10:36 AM
    battery completely dead in a week sndrk W126 S,SE,SEC,SEL,SD,SDL Class 12 08-19-2006 12:53 AM
    battery dead mjg99 W123 E,CE,D,CD,TD,TE Class 4 01-12-2006 07:14 AM
    Can't open trunk; battery completely dead! smartkey W202 C36 AMG, C43 AMG 3 03-14-2005 11:41 AM
    My 55 went completely dead today... masmole R171 SLK-Class 8 02-21-2005 06:22 AM
