Email from MBUSA about transmission service - Page 29 - Mercedes-Benz Forum
post #281 of 287 (permalink) Old 01-19-2011, 08:03 PM
Date registered: Jan 2011
I agree - its common sense- laws of physics in play
c280 bullmarket is offline
post #282 of 287 (permalink) Old 01-20-2011, 03:22 AM
Date registered: Aug 2008
Vehicle: 2008 E320 Bluetec, 1988 560SL totalled unto death). 1997 Dodge Ram 1500, 1983 300CD
Quoted: 178 Post(s)
Tran fluid change
This is a really old thread, about 2 years, but ... If the tranny fluid is not to be changed, why does it have a filter?
rocky raccoon is offline
post #283 of 287 (permalink) Old 01-20-2011, 09:26 AM
Kajtek1's Avatar
Quoted: 1250 Post(s)
The STRAINER is there to catch bigger pieces like dropped bolts, pieces of funnel (read the recent topic in W210 section) and similar.
If you take a closer look at the design, you might notice that the filter is actually a suction cup and the screen is just added to it.
Kajtek1 is online now
post #284 of 287 (permalink) Old 01-20-2011, 11:57 AM
Vehicle: 84 300SD (2 ea.), 98 E320 4matic Wagon, 51 Chev 1T pickup, assorted british motorcycles
I'm new to this forum as I only recently bought an E320 4matic wagon, 1999. It has 105,000 miles and I have a stack of service records 2 inches thick. Literally everything the dealer tech recommended was done.....Or at least it was listed on the R.O. One thing notable is the lack of a transmission service.
Yesterday I changed the trans oil and filter and drained the torque converter. I've changed a lot of auto trans fluid in my 40+ years working on cars. This was as dirty as I've ever seen. There was gray matter in the goo on the bottom of the pan. Looked like lead I used to find in engine oil pans from the days of leaded gas.
Anyhow I balked at paying $25/qt at the dealer for oil. So, I researched the specs and found that on 722.6 transmissions, Valvoline Max Life claims to meet the spec. A bottle I have from summer 2010 lists the 3403 spec that has been discussed on this and other forums. The Max Life Fluid I just bought lists the NAG-1 spec.
I changed the fluid and filter and after 50 miles it shifts just fine. If the trans craters anytime soon I will let you all know.
All this said, I was unable to measure the fluid level in the pan by any method: bicycle cable without housing, clear plastic tube or anything else I could stick into the filler tube. They all stop at the same place. So, I assume there is a screen at the bottom of the tube. I carefully measured the fluid I drained out and put exactly that amount back in.
Thomasa98 is offline
post #285 of 287 (permalink) Old 01-20-2011, 01:30 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Come join us in the W210 forum, there's a ton of great info. There shouldn't be anything blocking the bottom of the tube, though, you did something I have suggested in the past.
On a side note I'm pleased that my friend MM's thread still has some legs. And LOOOOOOONG ones, too.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #286 of 287 (permalink) Old 01-21-2011, 09:46 AM Thread Starter
Musikmann's Avatar
Quoted: 6 Post(s)
Originally Posted by gregs210 View Post
...On a side note I'm pleased that my friend MM's thread still has some legs. And LOOOOOOONG ones, too.
Haha Greg, I was surprised to see this one come back to life too.
Musikmann is offline
post #287 of 287 (permalink) Old 01-21-2011, 10:20 AM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
All this said, I was unable to measure the fluid level in the pan by any method: bicycle cable without housing, clear plastic tube or anything else I could stick into the filler tube. They all stop at the same place...
Whatever you stick into the filler tube eventually hits the bottom of the pan perpendicularly.
mbvis is offline
    MBUSA service manual thread suggestions? Teutone W126 S,SE,SEC,SEL,SD,SDL Class 11 08-27-2006 12:49 PM
    NY/NJ/CT = free service & recall info from Mercedes by email firebird MB Safety & Testimonials 0 11-11-2005 11:44 AM
    The Email I just sent to MBUSA Phonepro W210 E-Class 33 08-01-2005 06:48 PM
    ML Service Videos: General MBUSA Info CD pleubner W163 M-Class 46 07-24-2005 09:47 PM
    Anyone needs Instruction on Reset the service Light email me nguyensteve W210 E-Class 0 02-14-2003 08:13 AM
