Email from MBUSA about transmission service - Page 15 - Mercedes-Benz Forum
post #141 of 287 (permalink) Old 01-06-2007, 09:00 AM Thread Starter
Musikmann's Avatar
Quoted: 6 Post(s)
Question Re-flush & magnet
Originally Posted by Jayhawk
Did you ask them about a possible re-flush in the near future to clean out the stuff loosened by the first flush? And what about the magnet mentioned about?
Hi Jayhawk,
No, I only told the tech that I had wanted a flush in the first place. He became a little defensive and said "I only do what is on the repair order". I told him "no problem" and he convinced me I am "good to go" (at least for now) as far as the transmission.
I asked about the magnet when I made the appointment and was told they will not put anything foreign into the system (that came from the service manager).
When I was there, I asked again and the actual service writer said that the drain pan plug was probably magnetized. He was not sure, but had been a service writer for the same dealer's Jaguar division and only recently transferred over to the Mercedes side. His career began as a tech, and I think he is generally knowledgeable about these issues. I forgot to ask the tech, but I'll do that when I next see him.
Since they didn't do a flush, I have to assume that the service he did (gravity drain by all appearances) did not dislodge anything metallic that calls for an additional magnet.
And one last thing, my car's torque converter has a drain plug, the tech did tell me that. But why they don't routinely drain that too remains a mystery to me.
Musikmann is offline
post #142 of 287 (permalink) Old 01-06-2007, 06:44 PM
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: 2002 CLK430
Originally Posted by Musikmann
Hello friends,
I had my "transmission service" done today. There was a mis-communication between me and a new service writer, and I did not get a complete fluid change w/the flush.
For anyone interested in having a half-assed job, here is the breakdown:
Automatic Transmission Service:
(1) 140-277-00-95 - Transmission Oil Filter
(1) 140-271-00-80 - Gasket, Transmission
(1) 140-991-00-55 - Lock Pin
(4) 001-989-45-03 - Transmission Fluid (qt or lt)
Total for parts/labor was $221.70
For what this is worth, I asked about the full-flush service, and the service manager said it would be over $400. That would have been okay, and what I thought I was asking for.
Now I'm over $200 lighter, and have (at best) 50% new fluid. The silver lining to the dark cloud is that the transmission shifts more smoothly now.
Musikmann
One other thing, I paid about $340, but my receipt shows 9 quarts. I'm theorizing the extra fluid was used to flush the system. Your service writer said over $400 for what I think is the same service that I got. Are you getting a Mercedes Benz Club of America discount from your dealership?
MarcusF is offline
post #143 of 287 (permalink) Old 01-07-2007, 05:25 AM
Date registered: Jan 2004
Quoted: 34 Post(s)
I'm not positive, but I thought that adding the magnet to the earlier transmissions that didn't come with them was a TSB put out by Mercedes.
So, Musikmann, I don't understand how he can use 9 quarts if he didn't flush the system. Draining my transmission and torque converter took six quarts according to my service ticket. I'll be doing my own in a week or so, so I'll see if that number is right.
Len
'99 E300TD 99,500 miles
sokoloff is offline
post #144 of 287 (permalink) Old 01-07-2007, 06:24 AM Thread Starter
Musikmann's Avatar
Quoted: 6 Post(s)
Question MBCA discount?
O Mein Gott - you mean MBCA membership quaifies us for a discount at certain M-B dealers? I had no idea, but am a newer member. I'll look over what MBCA has sent me, plus make sure I ask the dealer about that - thanks!
I also assumed that your service required 9 quarts because some of that was used as the flushing agent. Even the service manager here told me they use new transmission fluid, not some chemical cleaning agent.
I'm almost positive that your $340 service and my hypothetical ~$400 one are the same thing. My operator's manual says an E320 holds 8.5 US qt (8.0 l). That looks like your flush only required .5 more qt than the stated capacity. That sounds very reasonable to me. It also tells me that I now have about 50% new fluid - I was afraid it was even less than that.
post #145 of 287 (permalink) Old 01-07-2007, 06:43 AM Thread Starter
Musikmann's Avatar
Quoted: 6 Post(s)
Question TSB on magnets
So, Musikmann, I don't understand how he can use 9 quarts if he didn't flush the system. Draining my transmission and torque converter took six quarts according to my service ticket. I'll be doing my own in a week or so, so I'll see if that number is right. Len '99 E300TD 99,500 miles
That could well be Len, but I think you wrote earlier that they started adding these around MY 2000; mine's a 2001, so maybe it already has one(?) I forgot to ask the tech, and the service writer was only guessing about mine having a magnetized drain pan plug.
My operator's manual says these E320 (and CLK430) transmissions (722.6xx) hold 8.5 qt so one of 2 things happened:
1) Either MarcusF's dealer only used .5 qt to flush his system or
2) They did a complete gravity drain, but since they had to use the 8.5 qt to re-fill it, they charged him for the entire 9 bottles, which they probably do no matter what type of fluid when they don't use the entire bottle.
Thanks in advance for adding this, and any further info later,
Musikmann
post #146 of 287 (permalink) Old 01-07-2007, 06:54 AM Thread Starter
Musikmann's Avatar
Quoted: 6 Post(s)
Unhappy Sorry, my mistake
Hello friends,
I had my "transmission service" done today. There was a mis-communication between me and a new service writer, and I did not get a complete fluid change w/the flush. Musikmann
I didn't get a flush, that was a typo - my apologies. It seems that the tech only emptied the drain pan (removing 4 qt/lt) replaced the filter, pan gasket, and the lock pin. Then he put 4 qt/lt back in, which means I now have approx. 50% new fluid and 50% old.
Parenthetically, the tech noted that the plug that they remove to use the special M-B transmission fluid-level dipstick was red, but they come from the factory with a black plug. His conclusion was that someone has done something with the transmission already.
I thought I had a complete service history on this car. What I have is a print-out of everything the original dealer (and who performed all of the A and B services) did to it. Now I'm beginning to wonder if the original owner took my vehicle to AAMCO (horrors, and a transmission shop we see around here) or Sears, etc.
post #147 of 287 (permalink) Old 01-07-2007, 08:08 AM Thread Starter
Musikmann's Avatar
Quoted: 6 Post(s)
Question Differing part numbers
Your transmission fluid has a different part number than mine. My receipt shows 001-989-21-03-10. It could be that yours was in liters and mine was in quarts.
Could it also be that one of our dealers has a high enough volume that they buy the fluid in large quantities, like I think they buy their engine oil in (I think) 55-gallon drums?
If so, it would have to be yours. This dealer here rarely does transmission services, at least on Mercedes - they also have Land Rover, Jaguar, and Volvo.
post #148 of 287 (permalink) Old 01-07-2007, 12:35 PM
Kajtek1's Avatar
Quoted: 1289 Post(s)
We are living in strange times, don't we?
Who do we suppose to trust with tranny service? The guys that do transmissions for a living doing tens of them every day, or MB dealer,that probably opens one transmission a month?
Kajtek1 is online now
post #149 of 287 (permalink) Old 01-07-2007, 01:57 PM Thread Starter
Musikmann's Avatar
Quoted: 6 Post(s)
If the dealer here does that few of them, then using some type of transmission specialist would be a good idea. In fact, the way you worded that, it makes perfect sense. However, I would be concerned about the availability of OEM parts, particularly the MB-spec ATF.
post #150 of 287 (permalink) Old 01-07-2007, 03:31 PM
MarcusF's Avatar
Absolutely we get discount - if you remember to ask.
For those that are wondering how big a discount, Musikmann was quoted over $400 for a service that cost me $338. Now, some may think, those are different dealers in different states, which are valid points. Yesterday I bought some parts at my local dealer. My total with MBCA discount was $146.14. The parts guy told me the total before my discount was $196.34.
MarcusF is offline
MBUSA service manual thread suggestions? Teutone W126 S,SE,SEC,SEL,SD,SDL Class 11 08-27-2006 12:49 PM
NY/NJ/CT = free service & recall info from Mercedes by email firebird MB Safety & Testimonials 0 11-11-2005 11:44 AM
The Email I just sent to MBUSA Phonepro W210 E-Class 33 08-01-2005 06:48 PM
ML Service Videos: General MBUSA Info CD pleubner W163 M-Class 46 07-24-2005 09:47 PM
Anyone needs Instruction on Reset the service Light email me nguyensteve W210 E-Class 0 02-14-2003 08:13 AM
