Outside temperature reading - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 11-22-2006, 07:48 AM Thread Starter
Musikmann's Avatar
Quoted: 6 Post(s)
Question Outside temperature reading
Hello friends,
Yesterday morning when starting the car, I noticed that the outside temperature indicator was about right at 45 degrees F. I drove about 1 minute, stopped at a place for about 1-2 minutes, turning the car off.
When I re-started, the temperature reading was somewhere in the 60s! As I was driving, it gradually adjusted back down, 1 degree at a time, until it was "correct" again. It continued to function normally for the next 50 highway miles.
I was on my in for service at the time, so mentioned it to the service writer. The tech came out later for a further explanation and I gave it to him. He gave it a road test and could not make it happen. He also said the incident did not leave an error code, and started talking about how difficult intermittant problems usually are to diagnose and fix.
We agreed that the "worst case scenario" was probably replacing the sensor. In the mean time, I'm supposed to be watching for it to happen again, and that maybe it will leave a code eventually.
Does anyone have any ideas, or do you think this is just another one of the often-mentioned Mercedes gremlins?
Thanks in advance,
Musikmann
Musikmann is offline
post #2 of 9 (permalink) Old 11-22-2006, 08:02 AM
Kajtek1's Avatar
Quoted: 1289 Post(s)
The sensor is mounted in front bumper. Very likely when you stopped with hot engine, you had a breeze, that pushed hot air from engine compartment up front. It doesn't happen all the time, but it occasionally it might. Get infra-red thermometer and check the bumper temperature if you are that curious.
Kajtek1 is online now
post #3 of 9 (permalink) Old 11-22-2006, 09:11 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 737 Post(s)
I wouldn't worry about it too much. I notice the opposite all the time. When it gets wet, it reads too low for a while.
GeeS is offline
post #4 of 9 (permalink) Old 11-22-2006, 10:11 AM
Date registered: Nov 2006
Vehicle: Mercedes CLK 320 Convertible year 2000
I have had this happen in the winter months when the air temp is cold and the engine is hot and the car stationary. I get a higher reading than I should sometimes. Once moving it seems to settle back to normal.
jchfloor is offline
post #5 of 9 (permalink) Old 11-22-2006, 12:02 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Thanks in advance,
Musikmann
Well, was that your SAT or TAT reading? And was your engine anti-ice on at the time?
Oh, sorry, forgot we're talking about cars here.
flyboyike is offline
post #6 of 9 (permalink) Old 11-22-2006, 02:03 PM
Ruudje's Avatar
Date registered: May 2004
Vehicle: 2008 Outback 2.5 XT, 1999 A4 1.8T, 1980 244 GL
Send a message via Yahoo to Ruudje
yes, definitely not something to worry about. The sensor most probably had the hot air of the engine to deal with.... and shows a much higher temperature. Had the thing showing temperatures of over 130 F when parked outside in our hot Californian summer. Usually in heavy traffic the reading is higher than usual (MB engines run pretty hot).
“One who conquers himself is greater than another who conquers a thousand times a thousand on the battlefield.”
Ruudje is offline
post #7 of 9 (permalink) Old 11-22-2006, 02:57 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 404 Post(s)
Previous answers are most likely correct.
I am more interested in the interior temperature than the exterior.
I know what I have set my climate controls to. But what I do not know is what the temperature actually is. I suppose I could hang a thermometer somewhere....
keyhole is offline
post #8 of 9 (permalink) Old 11-22-2006, 06:48 PM Thread Starter
Musikmann's Avatar
Quoted: 6 Post(s)
Thumbs up Thanks to all
I appreciate the feedback guys, but just as a final note: I'm not that concerned that the thing is even that accurate, +/- 5, or even 10, degrees is close enough for me, it just bothers me when anything in Benzie has a glitch
Again, thanks to everyone who responded,
Musikmann
post #9 of 9 (permalink) Old 11-22-2006, 10:38 PM
Diesel Benz's Avatar
Quoted: 39 Post(s)
The car would normally have multiple interior temperature sensors. Diagnostics would even allow reading those. But the readings would be confusing for an ordinary driver because you want the temperature to feel good and that does not mean a fixed centigrade value. Instead depending on the air humidity, sun shine strength and direction, fan setting (air flow level) etc. the car needs to adjust the actual A/C air temperature to reach conditions that feel OK for the driver (why not for co-passengers too).
Diesel Benz is offline
Temperature reading incorrect, Please help. Thank you 510stikiller W203 C-Class 1 10-05-2006 04:46 PM
External Temperature Digital Reading Smifster V-Class 0 08-11-2006 02:19 PM
Am I reading this right???? ByByeAmericanPie R170 SLK-Class 1 11-14-2005 04:47 AM
DB:DB^:MD:DB" if you are reading this... asianml Off-Topic 3 11-13-2005 07:34 PM
So..from reading the posts below..... Arnee C208/A208 CLK-Class 4 02-14-2002 07:48 AM
