battery dead on smart key - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 11-16-2006, 04:53 PM Thread Starter
Date registered: Nov 2006
Hi,
Since this is my first time here, i'm not sure if this question was ever asked.
My batteries died on my smart key for my 1999 CLK 320, so I replaced the batteries but the key still doesn't work. Does anyone know why this is? Any information will be greatly appreciated.
k820 is offline
post #2 of 8 (permalink) Old 11-16-2006, 05:00 PM
asianml's Avatar
Date registered: Sep 2005
Welcome!
Look for the key synchronization instructions either in your manual or in the W208 CLK-Class forum.
That should do the trick.
2002 Mercedes-Benz ML320 (sold)
2011 Chrysler Town & Country
2008 Toyota Camry Hybrid
2003 Yamaha V-Star 650 Classic
2002 Jaguar X-Type 2.5
asianml is offline
post #3 of 8 (permalink) Old 11-16-2006, 05:05 PM
Musikmann's Avatar
Quoted: 6 Post(s)
If your smart key stopped working, and after replacing the batteries it still does not work, the batteries were probably not the problem in the first place, but did you replace them with the same upside-downside orientation as they had been? I'm not sure that this is necessary, but that just occurred to me.
Also, the key has a little red light that is supposed to flash as you depress the buttons(s) Did you notice the behavior of this light before/after the battery change?
Good luck and welcome to the forum!
Musikmann is offline
post #4 of 8 (permalink) Old 05-11-2008, 11:29 AM
Date registered: May 2008
Hey, I own a '03 CLK 500 and my smart key is dead.. any1 know how I replace the battery?
CLK 500 Drvier is offline
post #5 of 8 (permalink) Old 05-12-2008, 03:12 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Would always help if you explain "what does not work". If the car does not start, it isn't an issue with the battery.
The user manual would (usually) explain how to change the battery from the smart key.
Diesel Benz is offline
post #6 of 8 (permalink) Old 05-12-2008, 07:13 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
To change the battery, remove the emergency key, and locate the litttle gray bar in the cavity, push it aside and the circuit board pulls out of the housing siimilar to a drawer.
Peter Guenther is offline
post #7 of 8 (permalink) Old 05-17-2008, 08:59 AM
'91 300CE's Avatar
Date registered: Jul 2006
Vehicle: 2002 ML320
The smartkeys have a lifespan... of 80,000 starts I think... after that the key needs to be replaced
Does the key start the car? If yes but does not unlock the car thats the internal battery.
If not... the key is dead... time to replace it
The key, no matter if the battery is dead or not, will be powered from the ring around the ignition slot via inductive energy so you can still start the car if the batteries in the key are dead.
You would have to open the car with the metal key, thus setting off the alarm, but when you place the key in the slot the alarm stops... that is if the car and key can agree on the code set. This cannot be done if the life of the key is up.
2005 BMW 325Ci - Sport, Premium and Cold Weather Pkgs
2000 C230K -- Desert Silver Metallic -- 113,000 miles -- Sold
2002 ML320 -- Alabaster White
1991 300CE -- Blue Black Metallic -- 129,000 miles -- Sold
1981 300SD -- Classic White -- 190,000 miles -- Sold
1977 240D -- Over 300k miles (Wrecked) -- My 1st car
2006 Porsche Cayenne S - Dad's
2004 Porsche 911 Turbo S
'91 300CE is offline
post #8 of 8 (permalink) Old 05-17-2008, 12:28 PM
I have not heard the 80K number , but the key is powered by inductive energy and replies via the IR, thru a redundant DAS path so it does not lock as a result of a power failure
    Wet Smart Key ... not so smart Joma W211 E-Class 18 10-20-2011 09:13 AM
    Smart key runs battery down Essellkay350 R171 SLK-Class 0 06-28-2005 10:47 AM
    BATTERY DEAD - KEY TOASTED - NO MORE KEYS AT DEALER - PICTURES - HELP sarrafo W163 M-Class 17 02-27-2005 07:12 PM
    Key fob battery died, is battery replacement covered under warranty? S4toML W163 M-Class 2 07-13-2004 09:14 AM
    Key battery goes dead ciruli W203 C-Class 1 03-06-2004 11:29 AM
