Replace Parking Brake Release Handle - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-13-2006, 12:01 PM Thread Starter
Date registered: Nov 2006
I have a '99 E320. The parking brake release handle broke off, and although the parking brake release is still operable, by gripping the shaft, I would like to replace this part. Is this a part one can buy and can a "lay" person(s) replace it? I have not taken it to a dealer or my regular M/B repair shop yet as I'm guessing it's not a cheap fix.
Thanks for any insight.
modmob is offline
post #2 of 2 (permalink) Old 11-13-2006, 01:58 PM
shandy's Avatar
Date registered: Feb 2006
Vehicle: 1995 C220 elegance auto.
The parking brake layout is shown here; http://www.detali.ru/cat/oem_mb2.asp...SGR=145&SGN=05
the handle should be readily available if you quote the part number. To replace the handle you must remove the driver side lower fascia panel,pull the release handle out to it's full extent to release it from the fascia then release the cable from it.
Hope this helps, George.
shandy is offline
    parking brake handle replacement drbranko R170 SLK-Class 0 09-03-2005 09:23 PM
    parking brake handle won't stay up - 99 SLK 230 drbranko R170 SLK-Class 3 09-02-2005 01:55 PM
    Hand Brake Release Handle joelsec W124 E,CE,D,TD Class 2 07-07-2005 08:03 AM
    Broken Brake Release Handle 1990 300SL hifeverz General Mercedes-Benz 1 03-22-2005 02:42 AM
    Broken Brake Release Handle 1990 300SL hifeverz R129 SL-Class 1 03-19-2005 12:08 AM
