two-door passenger seat tilted forward and won't go back - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-28-2006, 07:22 AM Thread Starter
Date registered: Oct 2006
I have a 1999 two-door convertible (C320, I think). On either front seat, there is a lever you lift, then you can tilt the seatback forward to admit passengers into the back seats. At the same time, a motor slides the entire seat forward to facilitate entry.
Here's the problem: the seatback has been tilted forward, but now lifting the lever does not allow me to push the seatback back. It simply won't move back. And now I can lift this lever with very little resistance. When it was working, it took a bit of strength to lift the lever - not much, but now the lever goes up with almost no resistance.
The electrical door panel switches still work fine.
Any idea what the problem is? To me, it seems like something used to be attached to the end of that lever inside the seat, and it somehow became disconnected. Can I get in there to have a look myself, or should I take it to the dealer? Is there some way to manually return the seatback to its normal position so a passenger can ride in the car?
Thanks in advance for your help.
simpytime is offline
post #2 of 2 (permalink) Old 07-15-2009, 07:50 PM
Date registered: Jan 2008
me too!!
Please someone answer this for me as well, I have had the same thing happen, except on my drivers side. I was able to get someone to get the seat back in place for me, but I am in the middle of nowhere on vacation with noone around that I would trust to actually work on this car. I am just trying to figure what broke, and my usual Benz dealer is not very helpful.
mine is a 2000 clk430. coupe;
Last edited by couturehottie; 07-15-2009 at 07:51 PM. Reason: added in type of car
couturehottie is offline
    seat wont go forward or back help.. Phade C208/A208 CLK-Class 18 05-04-2005 09:47 PM
    Engine does barely run after being parked tilted to the passenger side jwmol G-Class 11 08-30-2003 07:35 PM
    Rear second row seat bench (with arm rest) no longer slides forward or back brandon790 W163 M-Class 0 06-30-2003 12:46 PM
    Back passenger seat Bayer W163 M-Class 0 02-21-2003 10:24 PM
    Passenger side middle row seat can't fold forward c360825 W163 M-Class 8 11-03-2002 09:48 AM
