Automatic gear shift problem - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-26-2006, 02:58 AM Thread Starter
Date registered: Oct 2006
Hope someone can help out there. My car is an 1987 250 TD (automatic). The problem is that when the car changes gear the change is a hard shift and not smooth. I have been told that it might be a vacuum problem relating to the Injector pump? The headlights to go up an down automatically and the central locking works so there is a vacuum.
Bord1111 is offline
post #2 of 2 (permalink) Old 10-26-2006, 06:40 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Check your modulator valve on the side of the transmission.
flyboyike is offline
    semi automatic gear problem help Ali_c W168 A-Class 2 04-21-2016 01:30 AM
    A170cdi automatic gear box problem Guest (MBNZ) W168 A-Class 33 02-04-2014 04:42 AM
    How do I change my automatic gear shift knob? W124 E200 louistrd W124 E,CE,D,TD Class 8 02-10-2005 08:46 AM
    Automatic gear shift lever manufacturer?? gavjac W168 A-Class 0 06-22-2004 02:57 AM
    Automatic gear problem Per G-Class 2 11-10-2002 07:50 PM
