Oil Sensor Location - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-24-2006, 12:48 PM Thread Starter
Date registered: Oct 2006
Vehicle: 2000 ML320
Oil Sensor Location
Anyone know the location of the oil pressure sensor on a 2000 320ML. It was not unusuall for my 300SD to show low oil pressure when in fact it was a faulty (sensor) sending switch that was faulty and also leaking oil. Thanks for any help. Larry
LarryHarrison is offline
post #2 of 3 (permalink) Old 10-24-2006, 12:52 PM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 81 Post(s)
Search or post this on the w163 forum. I am sure a search of that forum will turn up something useful.
Mike
Michael Pillay is offline
post #3 of 3 (permalink) Old 10-24-2006, 12:55 PM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1003 Post(s)
Where is your oil filter? It is usually near that area like under it if you have a canister type filter.
DP is offline
    oil temperature sensor location scientist R/C107 SL/SLC Class 11 01-24-2006 05:59 AM
    95 E200. Oil sender sensor location, brake pad sensor location, engine code? cubicincubi W124 E,CE,D,TD Class 2 01-04-2006 09:07 AM
    oil pressure sensor location/ Nimrodthewombat W140 S-Class 5 10-06-2005 06:11 AM
    02 sensor bank 1 sensor 2 location sling_lphie W163 M-Class 0 07-27-2004 08:08 PM
    O2 Sensor location? trprice W163 M-Class 0 11-05-2003 09:02 PM
