C240 key wont turn - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-20-2006, 06:02 PM Thread Starter
Date registered: Oct 2006
Unhappy C240 key wont turn
I have a 2001 C240.
After a slew of sensor problems, transmission replacement, continuous oil level too high indicator,new battery it's now dead. Completely. When I put the key in, it won't even turn in ignition as it normally would if it was just dead battery.
Anyone have any idea what would cause this as the dealership's only recommendation is to tow it in.
Since my car is in the garage, I can't even get it in neutral to get it out so I can't access the battery to try to jump it.
In lieu of letting them rip me off right away as they always seem to do, wondering if anyone has ever experienced this
Nicolemarien is offline
post #2 of 3 (permalink) Old 10-21-2006, 01:22 PM
benzboyz's Avatar
Date registered: Jun 2005
Vehicle: W124/230E, W202 C240 stationwagon, W210 E280 facelift
you can try to open the bonnet and remove the a/c filter on the rigth side lower windshield (its just clip on) where the battery is located, or you can also open the center console coin holder. (pry it off with a suitable screwdriver) and insert a longer screwdriver in the hole where you pry the coin holder until you reach the side of the gear selctor lever, an emergency lever is located in that area and when you push this at the same time move the selector lever to neutral so that you can move you vehicle out.
benzboyz is offline
post #3 of 3 (permalink) Old 10-21-2006, 02:59 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 695 Post(s)
Oiled the steering lock? Jiggled the steering wheel when turning the key?
GeeS is offline
    Ignition key wont turn Docjay R170 SLK-Class 6 07-01-2008 08:49 PM
    my turn signals wont turn off SLICKSLK007 W203 C32 AMG, C55 AMG 2 10-18-2006 07:06 PM
    turn the key and dash lights turn on, no power to starter bob richards General Mercedes-Benz 4 01-13-2006 08:48 AM
    Ignition - key wont turn - 1982 280 SE Jenz_benz W126 S,SE,SEC,SEL,SD,SDL Class 14 07-03-2005 04:19 PM
    IGNITION KEY WONT TURN ETECHJOE W163 M-Class 2 08-25-2004 08:54 PM
